Red TZD to scrappers...bits for grabs
- Backslash Bandit
- My Cars: Cars
- x 3
Despite lots of care and welding over the years I've had it, the rear sub frame mounts made a nice crunchy noise when I jacked her up the other day so she's off to the scrappers.
However, I will be removing most/all mechanical parts for keeps (unless I have copious duplicate parts in which case they are up for grabs). So if you want any parts, just give me a shout and I'll try and sort something out.
Things that are definitely up for grabs are bonnet/hatch boot/doors in Venetian Red. Bonnet needs a respray though.
edit: Just thought I'd mention I'm located just outside Cardiff and that the bits wont be available for a month or two whilst I sort out my replacement and transfer some bits over
Re: Red TZD to scrappers...bits for grabs
pm sent
hi my wishlist is oval plastic pipe from air fillter . mudflaps and sunroof deflector
- x 160
I would like the wing mirrors if possible, I would like a couple of spares in case the local youth decide to rip them off again.
(now sadly gone)
(now sadly gone)
- x 160
Should be electric passenger on a TZD Jane so probably no use to you.
Tim Leech wrote:Should be electric passenger on a TZD Jane so probably no use to you.
Ah, I did wonder about compatibility. Sigh, back to eBay!
(now sadly gone)
(now sadly gone)
- Backslash Bandit
- My Cars: Cars
- x 3
The long plastic pipe that leads from air filter and runs along the top of the rad and joins the rubber 'bellows' by the fuel filter?bigmaclf wrote:hi my wishlist is oval plastic pipe from air fillter . mudflaps and sunroof deflector
Mudflaps I will need to check for you as they somewhere in my garage in various conditions
No sun roof deflector sorry
- Backslash Bandit
- My Cars: Cars
- x 3
Not available sorry - it's a 16v one and for keeps!Tim Leech wrote:Front bumper ?
- Backslash Bandit
- My Cars: Cars
- x 3
Tim is right about the near side being electric. I think I have some spare manual ones about so I'll let you knowmerlyn wrote:I would like the wing mirrors if possible, I would like a couple of spares in case the local youth decide to rip them off again.
Do you have the rubber pipe that runs from the back of the bottom of the plastic expansion tank, accross the top of the rad and back into the rad on the lhs as you face the engine?
I don't suppose the hydraulic pump is available if its a good one? My replacement one hasn't lasted that long, now that it's getting cold the steering is a bit stiff until the lhm has warmed up
- Backslash Bandit
- My Cars: Cars
- x 3
My steering has been going the same way..... It may not necessarily be the pump though, both FDV and more likely the pinion valve are worth considering as faulty units.....
- Backslash Bandit
- My Cars: Cars
- x 3
I do have it but I'm keeping it! Sorry, I appreciate the frustration but once one fails it's either gonna be ££££££££££ or NLA!Mothman wrote:Do you have the rubber pipe that runs from the back of the bottom of the plastic expansion tank, accross the top of the rad and back into the rad on the lhs as you face the engine?
Is this a 19 TZD saloon, or a TZD Turbo?
CCC BX Columnist
'89 16v P1
'93 ZX Volcane TD 3 Door
'98 Xantia Activa P1
'07 C4 by Loeb
3 x 2CV, 1 x Mehari
'89 16v P1
'07 C4 by Loeb
3 x 2CV, 1 x Mehari
