Last night my Activa started riding really roughly. On investigation I found it right down at the front. No worries, just the front height corrector link off.
Well, yes it was, I could see it dangling down. Simple, pop it back on.
No, not for me The balljoint has come away from the arm on the height corrector itself
So, it's a height corrector out job. It looks as if the ball was riveted on to a plate and the rivet appears to have pulled out. I'm wondering how successful a repair might be here. Anyone else suffered the same problem?
Also, how easy/hard is it to get the front height corrector out? On the face of it, it does not look exactly simple
Front Height Corrector - Broken!
- Sir Jim of the Databases
Jim
Just had mine replaced. Ouch!
Had Citroen Services in Glasgow check the ride height & when they tried to adjust the front up it either went too high or too low, apparently indicating it needs replacement (?).
Ayway, job done. £97 + £12 for the bracket + labour + VAT.
Can't help on how easy/hard a job it is. I have to get others to do the work for me as I don't have the time or the garage space any more.
FCF refugee
1998 Xantia 1.9TD Est Tempt 2
no the ball is not rivetted on it is just peened over were the peg goes through the bracket, i have welded a rear one back on before, thats if it has pulled out in one piece
