Tubilar manifold
I assume you mean a diesel??? (The 16V has quite a nice looking one as standard!)
What are you hoping to gain from a tubular manifold? By itself I wouldn't imagine it would have much effect - you need to work on each aspect of the head to get the most efficient flow.
IMHO the gains you would get from tuning a naturally aspirated diesel would be pretty poor compared to those from a turbo diesel
- BX Digit man!
Re: Tubilar manifold
Yes. I've put one in the boot before now. It made about as much difference as putting it on the engine. Mind you, it was a water manifold, and it wasn't for a BX engine.charlotte001 wrote:anyone put a tubilar manifold on the BX? where can I get one
If you want one you can get one from the tubilar (sic) mainfold shop. I believe it's next door to the rear brake caliper shop, and the torx screwdriver shop. All of these can be found on pointless road.
CaM
alledgedly the 16v breathes better with a nice set of headers on them. 8v petrol make less power, and not sure about diesel. seems pointless though.
on the 8v petrol engines I reckon ditching the AFM for carbs or map style injection would herald a better result as flap style afm's are quite restrictive. still flogging a dead horse really. In the bx's and such I prefer the 8v engine over the 16v for it's midrange torque. jsut seems to pull better than the valver.
need experience of the t/diesel engines
edit: the turbo diesel engines run a garret t2 turbo or similar don't they?
would be interesting to (i believe they use the same flange) strap a t3 or similar on there
t3/t4 hybrid would be fun. or a t28 roller-bearing turbo off a nissan pulsar/sunny GTiR.. would ned to toy around with turbine trim though, and of course fuel pump pressures etc.
