Alternator charging problem
DS Andy
FIXED
Post by DS Andy »
£15 for new BRUSHES and regulator from Bristol Auto Electrical, and now the alternator is putting out 13.6V again. I was concerned that the brushes might not sit well, but they're fine for now.
So I may well renew the TAX on the 8v Gti at the end of the month, then!
And maybe tackle the noisy front struts and nearside steering arms. Worn drop links, perhaps, new BUSHES perhaps!!!
Thanks for all the advice guys, and subsequent discussions!!
Citroen D Super 5 LHD 1974
Citroen AZU 250 1974 - ex Belgian PO 4-seater van
Re: FIXED
Post by kiwi »
DS Andy wrote:£15 for new BRUSHES and regulator
That gives me an idea of prices to look at as well.
Having not rebuilt an alternator before was they easy enough to do?
1990 BX19 TZS Auto 06/11/1989
Post by kiwi »
Here we go again
The New Zealand Spec BX strikes Again!
I took out the Alternator and slapped in a place I could not see while fitted was the specs of the Alternator and a logo!
Mitsubishi is the make and I was staggered to see 80 Ah as the output on the thing :shock:
Undetered after consulting with local mechanic he thinks that 50 Ah should be sufficant enough and as far as I can tell with Lights on, Air Con running not a significant differance and at least the warning light is no longer on.
God thing though is in theory the Misi Made Alternator should be easy to source parts given the Jappa crapper make is common on the road here. Actually I am considering pinching the one out my parents Mitsi Galant :lol:
x 103
just make sure it has the correct mountings, the japanese use a totally different mounting system for both alternators and compressors (bolts go straight into the block, not accross it through eyelets like ours).
Its a bit of a PITA as i work for a japanese company that mkaes alternators, but i can't borrow one for long term testing as they dont have french style mounts! :(
80amp is more what i would have expected tbh, UK 16v with aircon is 70amp as standard.
Post by kiwi »
I was joking about removing it from the parents Mitis Galant btw hence the :lol: icon :wink:
As of yet have not really "tested" the replacement Alternator under any driving conditions. First priority is removing that screech from cold with a belt adjustment.
