Thanks chaps. When it's a bit warmer out there, I'll start with the idle speed and lubricate as you suggest. I must say, this issue with vibration in 'D' while stationary leads me to think of double checking the engine mountings too.
I would attend to injector cleaning if there was someone local who could do it. As yet I haven't found a company that does it. I will try the mechanic I use down the road see if he can help. As it is, the injectors were cleaned by the previous owner about 22,000 miles ago.
I have a list of things to do on the car over the coming months and certainly Way2go I will (eventually) get the injectors done. One thing I'll need help in doing is testing pressure in the fuel rail.... but that too will be done.
Again, thanks everyone, for your advice.
Another hot-starting issue.
- x 27
