BX 1.9 Petrol rear brake calipers wanted
popdragin
Post by popdragin »
They was on the axle case when i bought it! thats the only reason
And the seem a nice small light wieght item, so i left them!
As for the fluid, with the green stuff work with my front calipers, wich is escort units
Brian
Post by Brian »
Popdragin Wrote:
"as for the fluid, its just regluar 'cheap' motor factors brake fluid! is that a problem? "
Possibly, all hydopneumatic Citroen's use green LHM fluid which is mineral based, DOT fluid is not, and may attack the seals.
It could make the seals either soft and expand, or hard and brittle.
The way to find out is split the caliper and inspect the two "O" rings, the small one between the two halves, and the large one on the piston.
What problem are you having with the rear calipers?.
If you use LHM fluid, then all the other seals in the braking system will require changing, and I doubt if you will be able to source them.
Impressive car by the way.
bloody hell thats cool!
Me want a go!
Are those CX rear discs?
popdragin
Post by popdragin »
Hummm, glad i posted now,
The only problem is the calipers are the none rebuilt theing on the hole car
They are volvo discs i machine to fit!
Liking it a lot! I remember the first I went to watch, I was walking across the field to the strip and the loudest engine I had ever heard fired up. And then it revved up! Beautiful.
Is yours running on standard pump fuel or methanol?
I wouldn't necessarily be worried about the seals, I've heard (indirectly through magazines/internet) of quite a few people apparently using BX front callipers on the rear axle (as they have an integral handbrake mechanism) of cars with a standard braking system. Perhaps dunk an LHM seal in some standard brake fluid and look out for any deterioration?
scarecrow
Post by scarecrow »
It's pink.
