suspension
Does it work on carp bait :wink: :lol:
Post by kiwi »
Grenman wrote:WD 40 is excellent
I use CRC :wink:
Post by kiwi »
Linegeist wrote:I suggest only on the same basis that clingfilm is a condom. :wink: :lol:
Na mate Rubber Glove better gets 5 times the use :lol:
Linegeist
Post by Linegeist »
:rofl:
Excellent news, thanks! I've got some pretty good welder's gloves here - I can see long term savings on the horizon!
rayfenwick
Post by rayfenwick »
Linegeist wrote::rofl:
...aren't they for protection from a different kind of slag? :lol:
Ray
www.citroencarclub.co.uk
Linegeist
Post by Linegeist »
:lol: Sharp! Very sharp!!! :wink:
scarecrow
Post by scarecrow »
(edit ^^^^^^^)^^ :lol: :lol:
I seem to remember it used to say on the can that it was, "developed by NASA as a lubricant for the Space Shuttle program".
The number of cars I've 'fixed' with WD40.... but only as a water dispersant, I wouldn't trust it as a lubricant with any longevity as it seems to dissipate very quickly. It did lube up my suspension rubber bits on the estate and stopped them creaking. There was still no creak after a couple of months so perhaps the rubber is porous forming a reservoir?
Bloody stuff stinks though!
Post by kiwi »
scarecrow wrote: "developed by NASA as a lubricant for the Space Shuttle program".
In an enviroment not exposed to water and road grit...
In space no one hears you scream :lol:
sub777w
Post by sub777w »
cleaned strut ram with wd40 then lubed with 10 40 engine oil worked a treet. thank every body for there imput. :lol:
1993 1.7 tzd red
1986 1.9 dtr white
sub777w
Post by sub777w »
Roverman wrote:Had the same trouble with my 16TRS, changed the spheres and it was still very stiff, get the car on its highest position, jack it up and take the wheels of each side, slide the plastic strut gaitor up and clean the shiny telescopic bit with WD40 and a cloth and then coat it with lubricant and see if that cures it, it did for me.
:lol: yes it worked cheers.
1993 1.7 tzd red
1986 1.9 dtr white
maxgreenwood
Post by maxgreenwood »
it has been said on this forum silicon based lubricant is good.
'90 16TZS (m), White, 86k
Yeah, I use it all the time....
Wait, are we still talking struts? :oops:
rayfenwick
:D
Ray
Linegeist
Post by Linegeist »
Can we define "Struts" here gents? :shock:
There are stiff struts, thick struts, weak struts, struts wot dribble their contents when operated, struts that can be pumped up, wobbly struts - and even super extendable struts ...... all of which benefit from lubrication (and being used).
I'm getting confused (in a very manly, backslapping kind of way you understand....) and I need a cold shower ......... :wink: :lol:
Mat wrote
"Wait, are we still talking struts?"
that type is spelled sillyc*nt lubric*nt isn t it, TEA HE
