That was one of the last clues to the burn't valves as unburned petrol vapour was in the exhaust system (with an occasional backfire tooscarecrow wrote:
And if the tappets were over adjusted... hmmm
..................... - I have noticed a strong smell of petrol when parking up on very hot days so that is an issue .
Hot-starting issues
scarecrow
I'm sure that this is the unobtainable part that the garage finally managed to source in Germany, so it shouldn't be an issue.Sounds like the anti-stall diaphram
I can see I'm going to have to pay out to have these repairs checked (tappets too) if I can't find a gasket problem with the techniques suggested.
Thanks for the advice
electrokid
Unlikely - several places in the UK still provide carb recon kits - pull the vacuum pipe off and sniff it - very easy quick test to be sure.I'm sure that this is the unobtainable part that the garage finally managed to source in Germany
2002 C5 HDi SX estate
