Brian wrote:The tool for 3.5mm pipe would be most useful.
Has any one had a go at making such a tool?.
If I had access to a lathe I would certainly have a go, and I guess only moderate hardening would be required when using the softer Kunifer / Cupro Nickel pipes.
I made some experimenting with different designs for a DIY Citroën hydraulic pipe flaring tool. The one I ended up using is a simple design made from scrap iron and a threaded bar. This design enables you to join hydraulic pipes even in the field conditions (=underneath the car).
I also experimented with a more innovative design, which - even though it seems to work - is unfortunately not very convenient to use. The idea behind this design was to use only a lathe and a bandsaw in making the tool, as I was not certain I would be able to drill a sufficiently straight hole to enable the design of the first link. Here in Finland, a 3,5 mm pipe costs about 4 euro/meter, and the unions are around 2 euro per piece (if you do not make your own unions, which is pretty straightforward if you have access to a lathe).
Another quote from the same thread:
But if you have access to even simple machine tools (= a drill, and preferably also a lathe to help making the punch holes exactly centered), it's not too much work to make one of those:
There was a long(ish) discussion on the Finnish Citroën forum about a year ago, with several different ideas for a tool proposed, sketched and discussed. There (from page 2 onwards) you can also find the correct dimensions for the flare.
BX Van 1.9D -90 Gone.
BX Van 16S -90 For sale.
Nat wrote:pliedes aren't selling the tools anymore, I phoned up after one last week and they'd stopped selling them unfortunatly, I found another place on the web that sold the tool for £100 for the 3.5mm but then you had to pay a further £45 for the 4.5mm adapter if you wanted it, same again for the 6.35mm adapter too.
See now thats a worry. They didnt have any 6.35mm pipe in when i called before christmas, with no clue on delivery date. Now they do not sell the tools flaring tools anymore. Hydraulic specialists? Not on your nelly it seems.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
