Chirping noise
The clonking saga: It appears to eminate from the front height corrector. Not sure why but it does make quite a clonk, Shaune had a fiddle & reduced the amount of clonking that it made, but didn't want to move the height corrector too much incase it caused an issue.
Anybody experienced this same problem? & how did you solve it?
maybe its you lower engine stabaliser bush/mountting,
check both ends for play/movement, i have seen the were the sub frame end has been loose for a long time, the eye in the sub frame becomming oval,
I suggested on another thread that it could be the inner tie-rod balljoint clonking as it's cactus'ed. I suggest this as it's directly behind the height corrector and I've got my steering rack out at the moment and I can make this joint clonk by tapping the outer tie-rod with my hand. It's history but hasn't done bad for 25 years old.
I don't see how the height corrector can clonk against anything really..
I think its making the height corretor linkages make the clonking sound??
i would say there aint much in/on the linkage that could clonck,
also toddao i think the steering ball joints are spring loaded, so hitting with a hammer could possibly cause a knock,
I didn't hit it with a hammer Malcolm. I save my Sledge.. sledgehammer for sensitive work! I was saying that the axial ball joint is so shagged that it clonks just with hand pressure.
ok sorry toddao
well it does start with H :lol:
