STOP Light
rayfenwick
- Yahoo Messenger: otis_wilbury_ii
That's French wiring for you.
Ray
www.citroencarclub.co.uk
rayfenwick wrote:Ah...so was there a warning light to warn you that the buzzer warning that the warning light warning of other warning light failures had failed, or was that a buzzer too?
Way2go wrote:BX DIY wrote:There are a few diodes in the instrument panel operating the STOP light so that it comes on simultaneously with any of the major warning lights. Should one of these diodes become shorted, one warning light (eg. low LHM level) can trigger another one (coolant level) erroneously. The easiest way to check this would be to short the coolant level and LHM level sensors one by one to observe whether any of them triggers a second light, too. The oil pressure switch, on the other hand, is supposed to light up everything else: this is what happens when you turn on the ignition but do not start the car yet.
The diodes are very cheap from a common electronics store, a few eurocents each, so you could renew all of them while you're at it.
It would appear all you need to do is to fit a push-to-make switch that bridges the oil pressure switch. However as the BX does this check automatically when you turn the ignition on - is there any point to it?rayfenwick wrote:My CX 22TRS has a "check" button which lights all the warning lights when pressed. Maybe not a bad idea for a BX either - shouldn't be too difficult to fit (he says, now realising I've volunteered myself to experiment).
rayfenwick
Ray
have you checked all the fluid level's,
i saw a fault years ago on a BX were all the warning lamps lit with the engine running,
turned out he engine oil was low but also one or more diode's had failed, which caused all the lamps in the lline to light up,
