Ours seems reluctant to comfortably cruise above 72, although it will do 90. I suspect the very recent extraordinarily good emissions result for its MOT means its underfuelling?Dollywobbler wrote:At the risk of a mighty Off Topic, are they that undergeared compared to the turbos? I make it about a 300rpm difference at 70mph and mine seemed quite happy sitting at 80mph. Mind you, almost fell out with my BXagon co-pilot before we'd even left the M25 after he hit 90. I almost hit him...
Ebay - high mileage TZD estate w/o MOT
- x 27
Mine just seems noisey, so i just keept he car to 3000 revs in 5th & cruise along around 64mph & get nearly 60mpg on a run
Mine does rev easily into the redline, perhaps the k&n panel filter helps??
- x 27
It's not right, and I suspect with adjustment of the fuelling it will get a little more oomph. I agree with Mr. Mulley though, it's a bit too busy at higher revs: 3200-3500 is about as much as you really want to sit at for any amount of time.Dollywobbler wrote:Doesn't sound right. Don't get me wrong, they are a bit busy at speed (but then my Pug 306 DTurbo felt the same) but neither of my TGDs felt unhappy until the fast side of 80.
