Knocking engine and burning oil when hot
Max don't get rid or disheartened. I would get some quotes from another garage or try a Citroen specialist this side of the water. Dave Ashworth is in Blackpool so you could come over via Larne to Heysham treat it as a mini-break. Hope this helps. Mark.
maxgreenwood
thanks Mark i'll look into that. Labour is certainly cheaper in the UK as well as parts when converting the euro to the pound.
I'm not disheartened really, I've come to accept this as par for the course when being into old cars. I didn't buy wisely and was kind of aware of that at the time. However i ploughed a bit of money in and now the engine needs a serious rebuild. The car is a bit rough but does have it's good points. There are a few holes that should be welded up, and sensibly I should just find a better one with a more solid shell, but there's a possibility i might get the engine work done at some stage if it's reasonable price wise in the uk / or i might go the route of replacement engine just for the interest and sense of achievement, and to have her working well again.
I can't drive it at the moment, it's just too smelly, it's gotten particularly bad in the last week. Put some 'stop smoke' in today and that hasn't made any difference.
I've currently got anl XM estate in my sights. But i couldn't live without a BX. I'll miss it, and that will get me to get moving on doing the work on it i would imagine.
'90 16TZS (m), White, 86k
Willy
maxgreenwood
er... i wouldn't say that. I'd be interested in keeping them for another BX. They're fairly rare. I prob wouldn't put them on the TZS as it wouldn't suit i don't think. i like the buck-rogers hub-caps.Does this mean you might not need anymore those olds alloys you've been given?
Someone else is welcome to them if they can be picked up before i can get to them, i'll probably collect them in the next couple of months.
I'll keep them safe though should anyone else require some in the future, maybe in exchange for some engine work
maxgreenwood
Suitable engine replacement
What would be the easiest/most suitable transplant engine for a 16TZS (carb)
And no i don't want to convert it to diesel!
Are all Pug/Renault/Cit 1.6 engine from that era similar?
What about a 1.6injection
Forget Renaults, but 205/309/405 should give more possibilities. Injection means more complexity (wiring loom/fuel pump etc) and I would advise against unless a donor car is to hand. The only non GTi 205 I can think of is the auto, and not 100% sure that isn't injected too...
A 1.9 carb engine might be a nice swap, just as easy as putting in an identical 1.6.
Indeed the 1.9 does give it quite a bit more oooomph! richard from wakefield was breaking a 1.6/1.9 auto?mat_fenwick wrote:Forget Renaults, but 205/309/405 should give more possibilities. Injection means more complexity (wiring loom/fuel pump etc) and I would advise against unless a donor car is to hand. The only non GTi 205 I can think of is the auto, and not 100% sure that isn't injected too...
maxgreenwood
sounds good to me. Pm sent to Richard.
Is it just the TDs and Gtis then that used the thicker driveshafts?
And what's the deal with my new clutch, i suppose that will be replaced too
Willy
Hypothetically speaking, what other engines would work for a straight swap? I also have the XU5 carb with similar mileage, the rest of the car being in good shape and imagine one day it will also phail or prove too expensive to fuel. Ideally I'd like the XUD9 or a DW8 (306, Berlingo etc) if it'd fit.
DW8 has the same basic bottom end as the XUD, but I believe the heads are different and it is ECU controlled. Should physically fit no problems, but an XUD swap would be more straightforward.
But still a step up from swapping in another carb engine - you have the glowplug wiring to consider, different throttle cable, fuel tank to drain and refill, rev counter to change etc...
maxgreenwood
i wouldn't really want to go there i don't think, i like the idea of a simple 1.9 carb.
Perhaps a 1.9 twin carb like the BX sport, now that would be pretty good fun, probably tricky though and expensive and not great on fuel!
Haha try finding one! trust me the 1.9 with the twin choke carb is quite adequate! and a starting difference from the 1.6, which in itself is now slouch. I know David rutherford had a 1.6 engine and box out of snoopy a while back.maxgreenwood wrote:i wouldn't really want to go there i don't think, i like the idea of a simple 1.9 carb.
Perhaps a 1.9 twin carb like the BX sport, now that would be pretty good fun, !
Did Leobx16v get rid of the engine/'box from his crashed valver? Would make an interesting conversion especially with carbs replacing the efi system.
