At my wits' end with this bloody ZX - intake boost results
djoptix
Well my Synergie only ever gets 45mpg, on the same engine. Mind you Parkers says it should do 36 so... should I start fiddling with the fuel pump to see if it can get better?
It doesn't have much noticeable boost, but I have always put that down to the fact that there's miles of pipework from intercooler to turbo and then back to inlet manifold...
Oscar
Phil I agree largely with you, but I'm persevering for the moment, for a few reasons. I like things to work properly, and I get a lot of satisfaction from making them work properly, so this is a bit of recreational tinkering. And I know the XUD engine relatively well. We don't do that many miles in it, so it's not a crippling cost. And I'm generally averse to throwing things away. Plus SWMBO likes it, which is v. imp.Philip Chidlow wrote:Get rid. There are so, so many cheap alternatives at the moment. Please remember the old horse, dead and flogging adage.
Although I'm sure she'd like a Volvo estate even more, but I'm reluctant to open that particular possibility.
We'll see how it does. I'll get this sorted, then the rear wheels will collapse or something.
- x 25
Usually memat_fenwick wrote: who gets rid of a car when it's running perfectly and there are no big bills on the horizon?
Oscar
Now down to 29mpg
Really haven't a clue what might be wrong with it. I shall have a good look over for leaks this weekend, but other than a fuel leak while running, I can't think of anything else to fettle.
It's gone from 43mpg to 29mpg in my ownership.
Get shot & get another one, they are cheap anyway's. Or find a garage that knows their zx's inside & out & perhaps they can diagnose the issue(s)? A pain in the arse.
Actually, have you had the injectors checked?
Oscar
Bolxxcks as they say. If no fuel is leaking, then its chewing diesel at a high rate. Does it smoke a lot, that would suggest overfueling?
- x 94
Oilyspanner
Oscar
Hi Stewart
I don't think it's the pump now. I've adjusted it backwards and there's no smoke so it should be fine. I think the handbrake is binding on - the rear wheels didn't spin very easily when I jacked it up this morning. I took it down to Medway Citroen but they didn't have a spare ramp. I'll have a fiddle with it tomorrow morning.
Pissed off now.
Pissed off now.
Simple fix if its just binding brakes, did you ever see how hot the wheels would get after a drive? Thats usually a giveaway that something is binding. Perhaps keep the faith a little longer
Oscar
