4sale BX GTI 4x4 only 82kmiles
Nat
it does require special oil, yes. I have some which I got for mine, was a b**** to find though.
Torsen is a type of limited slip diff, not the most sophisticated type, but works to some extent. The main problem with them is the torsen properties rely heavily on the properties of the oil which degrade with time and use so after 20 odd years it wont be very limited slip if you get what I mean, it wont fall apart or anything though so not the end of the world.
1991 BX 4X4 GTI back on the road
BX4x4
Jayboy
Been a fair bit of the correct oil on eBay over the last couple of months, although I have failed to actually buy any....
CCC BX Columnist
'89 16v P1
'93 ZX Volcane TD 3 Door
'98 Xantia Activa P1
'07 C4 by Loeb
3 x 2CV, 1 x Mehari
'89 16v P1
'07 C4 by Loeb
3 x 2CV, 1 x Mehari
BX4x4
Mike E (uk)
I would not worry about the exhaust much.
If it cannot be welded up ,Custom stainless pipes are widely available,
or
if you have the remains of the original pipe to copy,and some standard BX GTI silencers, a system could be fabricated without much trouble.
If the transmission works, then the problem areas will be the same as for any 1990 BX GTI.
Mike
or
Mike
BX4x4
Mike E (uk)
"what are the normal problem areas for a GTI?"
...Much the same as for any BX.
8V engines suffer from hard valve guide oil seals giving high oil consumption, but otherwise the engines are strong.
The normal BX problem areas: rear trailing arm bearings, rusted hydraulic pipes, rusty boot floor & inner wings, faulty ABS sensor wiring, bad electrical connections.
If the car has been stored in the dry, it will need new tyres, a cam belt and a service. But all the faults it had when it was stored won't have gone away.
Rust would be my biggest worry.
I have found all used cars to require more attention than I first anticipate though.
-this car does sound like it has potential.
JayW
- x 13
JayW
- x 13
Jayboy
Which cars do you want to see pics of Mr 4x4?
CCC BX Columnist
'89 16v P1
'07 C4 by Loeb
3 x 2CV, 1 x Mehari
'89 16v P1
'07 C4 by Loeb
3 x 2CV, 1 x Mehari
All of em
BX4x4
assembled
- My Cars: 1991 Citroen BX TZD TURBO 4WD*
*aspirational - x 2
The oil for 4x4 is "Total transmission x 4". At least in Lithuania Total dealer has it in stock. 1,7l of it goes to rear diff. It must be changed every 20kkm.
In non-ABS models a limited slip rear diff was used. Torsen rear diff was used in ABS models and it is actually set of gears that multiply torque of one wheel to other thus if one wheel is in the air, the other receives 0 torque.
1991 TZD Turbo berline
Ex 1992 TZD Turbo berline, aircon, ABS
Ex 1989 GTi 4x4 berline, ABS
BX4x4
