well, I put the light back in this morning and have been to Manchester and back in some quite foul weather and the light is still there and working.
kev
head lights caution !
tzd
It isn't just a car it is a BX and it's my BX. Long live the BX.
Oilyspanner
I have had a few come off over the years, silicone always worked fine for me, just clean and dry both surfaces and go for it. might be a good idea to pop the headlamp off and do it indoors this weather though. I have probably got a lamp if you need one.
tzd
hi oilyspanner,
thank you for the offer but it seems like it has worked with silicone. I sharpened the end of a 3mm screwdriver and used that to clear out all of the old adhesive, leaving a clean channel for the silicone to do its job.
I did it in the house and put the headlamp in front of a blow heater for the day to make sure it had cured.
Seems ok for now.
I noticed the other side needs doing so I may be doing this in the next few days.
cheers kev.
Seems ok for now.
cheers kev.
tzd
Hi Andy,
I'm not sure about the mark 1 ? Mines a mark 2 and it doesn't have any.
Kev
Kev
