Cooling System misbehaving again!
andycadabra
andycadabra
I tried your test, Mat, but couldn't detect any hissing... I've managed to source a thermostat cover from a main dealer for £10.50 plus VAT, which will be coming in Friday. Once the system can stand being pressurised, I'll use the k-seal, and hope for the best.
I've only done about 12,000 miles since the new cylinder head and gasket was fitted, but it could have been sabotaged by the waterpump and/or the horribly clogged up radiator that I was using before fitting yours!
Does my idea of testing the waterpump by timing flow through the radiator sound like a good idea? All other tests I have read about for waterpump fault diagnosis can't be used on these engines.
1992 BX 17TZD 130k
1987 BX 16TRS SORN
1987 BX 16TRS SORN
andycadabra
well it looks as though the K-seal has worked! No more coolant being forced out of the radiator cap, no more bloated hoses threatening to burst...
I have only had it at tickover so I just hope the repair holds when the engine gets a bit more exercise..
now I just have to deal with the mysterious loss of dipped headlamp(main beam ok), since the time coolant was getting regularly sprayed around the engine bay...
Thanks to everyone for their input.
1992 BX 17TZD 130k
1987 BX 16TRS SORN
1987 BX 16TRS SORN
andycadabra
andycadabra
ok, I see! - http://www.bxproject.co.uk/phpbb3/viewt ... =2&t=3771- but will be a small price to pay compared with another HG/head job!
1992 BX 17TZD 130k
1987 BX 16TRS SORN
1987 BX 16TRS SORN
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
andycadabra
That should be a sticky qoute somewhereelectrokid wrote: filling up with tapwater is the quickest way to damage the engine to the point where it needs a lot of topping up...
When you've found the problem and fixed it - fill with antifreeze (which contains an inhibitor to prevent the kind of corrosion that causes water leaks) and distilled or de-ionised water - never tapwater.
Guilty of this myself withwith the issues I hae witht he TZS at the moment. One question though wold rainwater be better than tap water?
Given I am in the clean south pacific unless there has been a dust storm in Aussie our rainwater is still drinkable.
1990 BX19 TZS Auto 06/11/1989
If the rainwater was stale, i would have thought that would be ok, otherwise fresh rainwater only marginally better than tap water which has treatment chemicals in it, but not as good as distilled water which is better than everything.
andycadabra
Re: Cooling System misbehaving again!
1.9td from a 61k 306 going in this week. Havent yet traced the ideal 1.9 non turbo camshaft, so might need to use the 17TZD one..
1992 BX 17TZD 130k
1987 BX 16TRS SORN
1987 BX 16TRS SORN
