Ok. I found the pack-of-five nipples part.no 1306.76 which is listed only as the bleed for the brake control valve!There were two still in the packet - so obviously they didn't fit afterall.
Then I measured the front bleed from an original Bendix caliper from a 85 BX. The gauge read M.7 which doesn't really exist as far as I know. It's got a finer thread too than the M.8 bleed so heaven knows what this thing is. Ideas on a postcard to : Odd French thread comp, Blue Peter.
Typical Citroen eh?
nipples
- BXpat
Re: nipples
Re: nipples
must be a German thing as i could not see packs of five nipples on service citroentoddao wrote:Malcolm wrote
service Citroën dont list a kit with a nipples in
saucy devils!
I only wanted to buy the doseur bleed and all they could supply was the five-in-a-bag...... nipples
Re: nipples
toddao wrote:The gauge read M.7 which doesn't really exist as far as I know. It's got a finer thread too than the M.8 bleed so heaven knows what this thing is. Ideas on a postcard to : Odd French thread comp, Blue Peter.
M7 x 1mm pitch
http://www.namrick.co.uk/acatalog/Home_ ... s_150.html" onclick="window.open(this.href);return false;
- BXpat
Re: nipples
XU sump bolts are also M7 x 1mm, just in case you ever wondered...
Re: nipples
Earlier cars, like 2CV's, GS etc. have loads of M7 bolts - if you think they're odd, try finding replacement M9 bolts for the Dyane front valence!
Re: nipples
all OE 3.5 pipe flare nuts are M7,
Re: nipples
That site's prices are even more expensive than Citroen
