Red TZD to scrappers...bits for grabs
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Re: Red TZD to scrappers...bits for grabs
Sorry - TZD Turbo - Hatch
Jayboy
Ok thanks. Doesn't have the bits I want then....
CCC BX Columnist
'89 16v P1
'93 ZX Volcane TD 3 Door
'98 Xantia Activa P1
'07 C4 by Loeb
3 x 2CV, 1 x Mehari
'89 16v P1
'07 C4 by Loeb
3 x 2CV, 1 x Mehari
Hi, would you have the spare wheel carrier bolt n hook available?
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
I think I do yes. I'll check....
If you have one ile be well interested bud.BX Bandit wrote:I think I do yes. I'll check....
bigmaclf
hi do you have a rubber door seal drivers doodBX Bandit wrote:The long plastic pipe that leads from air filter and runs along the top of the rad and joins the rubber 'bellows' by the fuel filter?bigmaclf wrote:hi my wishlist is oval plastic pipe from air fillter . mudflaps and sunroof deflector
Mudflaps I will need to check for you as they somewhere in my garage in various conditions
No sun roof deflector sorry
bigmaclf
bravo-x-ray
Hi I'd be after a couple of parts, tailgate complete ie with spoiler etc, and a doseur valve to rebuild to replace mine and both headlights and all mounting paraphernalia as my 'valver came with morettes on her and I'd like to have toe option of putting her back to factory spec further down the line.... Good shout came from the wife as I was typing this was a parcel shelf and the boot curtosey light....
I know its alot, but it will help keep another one running for another twenty years....
(yup its in black and white I'm committed now
she will still be running twenty years from now
Formerly known on here as The Death Wolf many (howled at) moons ago....
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
bigmaclf wrote:hi do you have a rubber door seal drivers doodBX Bandit wrote:The long plastic pipe that leads from air filter and runs along the top of the rad and joins the rubber 'bellows' by the fuel filter?bigmaclf wrote:hi my wishlist is oval plastic pipe from air fillter . mudflaps and sunroof deflector
No sun roof deflector sorry![]()
Think it's ok, but I'll have to check and let you know.
bigmaclf
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Tailgate with spoiler is available but it's the Mk 1.5 (early type) 16v spoiler and not the whale tale type. PM me your email address and I'll send you pics of the boot/spoiler. Also two lines of the rear heated screen have failed but should be an easy fix with some conductive paint.bravo-x-ray wrote:Hi I'd be after a couple of parts, tailgate complete ie with spoiler etc, and a doseur valve to rebuild to replace mine and both headlights and all mounting paraphernalia as my 'valver came with morettes on her and I'd like to have toe option of putting her back to factory spec further down the line.... Good shout came from the wife as I was typing this was a parcel shelf and the boot curtosey light....
I know its alot, but it will help keep another one running for another twenty years....![]()
(yup its in black and white I'm committed nowshe will still be running twenty years from now
*May* be able to do headlights but they'd have to be re-bonded as the glass came off. I think Aerodynamica has a pair for sale on here though. I can do you the mounting paraphernalia though.
No parcel shelf though sorry and I'll have to check on the boot light - they break so easily I'm not sure if any of mine are fully functional but I'll check.
Think I have a spare doseur too. Are refurb kits available then?
If the boot light's broke, I think the glove box one fits.
bravo-x-ray
Hi I'm looking for a doseur valve and a couple of ABS driveshafts if they fir the 'valver gearbox, i'm also after the near side indicator and drivers side courtosey light.
saintjamesy89
1990 Volvo 740 2.3 GLE Estate
Do you have any steelies? I'm after a set as those on the TXD seem to be quite bent and buckled...
2013 Nissan Leaf Acenta 24Kw
bravo-x-ray
I have a set of steelies with my winter tyres on them, currently in use, you are welcome to the rims when I find some speedlines for the summer tyres I'll put the winter tyres on the other set of alloys and you can get my steelies.
