Over-temp lights questions
Re: Over-temp lights questions
It doesn't work accurately as the wires normally break internally from age, so the lights flicker because of the vibration from the car whilst on the move as the internal wires are connecting & disconnecting slightly. I changed my wheels over anyway's so always check the wear of the pads at the tme, so don't need or rely on a light to appear which most likely won't mean that the pads are low. But if you have one's that work & you want to rely on a light to appear, thats fine also
I don't follow this Mulley.MULLEY wrote:It doesn't work accurately as the wires normally break internally from age, so the lights flicker because of the vibration from the car whilst on the move as the internal wires are connecting & disconnecting slightly. I changed my wheels over anyway's so always check the wear of the pads at the tme, so don't need or rely on a light to appear which most likely won't mean that the pads are low. But if you have one's that work & you want to rely on a light to appear, thats fine also
If you are getting false indication (or flickering) then something on this route is getting shorted to earth elsewhere.
B-Hive
My first TRS's pad warning lights flickered down to the fact that the wires had broken off the sensors and were free to earth themselves on the abundant metal bits, and so I am guessing that this may be the usual cause, even if the wires haven't come completely free, they may well be frayed at the top leading to shorting out on the brake calipermat_fenwick wrote:Whilst the pad warning system isn't ideal (for that reason I'd never rely on it) it's handy but not a failsafe system. I.e. any break in the wiring will cause the lights NOT to come on when the pads are worn. TBH I've never known the BX to give flickering problems, unlike failsafe systems which come on if the wires are broken.
Current
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
85 BX TRS mk1 auto... SOLD
90 BX TRi..parts....cubed
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
No idea why it does this way2go, i think the above post probably answers it better than i could. Either way its a shit system to rely on, when you should be checking your brake pads physically anyway. I also ask my MOT tester to let me know how much is left on the pads as well so that i can judge how long they've got left before needing to be changed incase they are low but don't fall within the advisory notice.
electrokid
You're right...They don't light up for test - which is really REALLY stupid.
Easy to modify it though - a device that briefly operates a relay (with 2 sets of contacts) or 2 relays to short the sensors to ground and so operate the lights. For a diesel there's already such a device - drive the relay(s) from the glow plug feed.
You and me bothYet I STILL haven't got around to fitting the temperature gauge I bought over a year ago...
2002 C5 HDi SX estate
Birotor
I would not trust a MOT tester with no BX specific experience. The factory say ' change when the light comes on' it does NOT give a minimum thickness. I would however accept my own visual examination once I had seen a pad showing the exposed wire which on a GS means about 500 miles of normal road use on a 1220.
I personally know my MOT tester, that's the only reason why i'd ask him as he's usually spot on, but i see your point though.
the brake pad warning light should, if it's working properly, come on when there are 2MM of friction material left on the pad.
Personally I've never trusted any form of pad warning light (on cars or buses / trucks) and much prefer keeping a physical eye on them on a regular basis.
That said, for those that dont tend to take their wheels off r check under the car on a regular basis, every extra helps, although again, I've never run my pads down to 2mm.
