tzd problems
the citroenman
Re: tzd problems
Post by the citroenman »
have sorted the problem back tyres that where new where not up to it been back to the garage got them changed plus why carnt a bx get to the 132 mark then going down hill flat out from the 74 on to the m6 answers on the back of a post card please its not imposible
Thread Bear
Re: tzd problems
Post by Thread Bear »
My BX can do nearly 200 MPH from several parts of Britain. Its called Terminal Velocity. Its sure to duff the engine though. You do not need balanced or good tyres though. :P
the citroenman
Re: tzd problems
well if the speedo has gone wrong do you know more on the problem and whot do i need to do to sort it out as i dont know a lot on how the car works i know whot your saying but 200 mph as a answer dont help how i sort the problem
BX Bandit
Backslash Bandit
My Cars: Cars
Re: tzd problems
Post by BX Bandit »
The 132 or whatever speed is rather theoretical, I.e. Speed where the engine hits the governor, but as the engine is not greatly powerful overall the wind resistance proves too great. On a standard setup you won't see change out of 110, not sure I've ever got there but you should reach 100 with no real problem, perhaps a salt flat would help if you want to try any faster?
Re: tzd problems
BX Bandit wrote:The 132 or whatever speed is rather theoretical, I.e. Speed where the engine hits the governor, but as the engine is not greatly powerful overall the wind resistance proves too great. On a standard setup you won't see change out of 110, not sure I've ever got there but you should reach 100 with no real problem, perhaps a salt flat would help if you want to try any faster?
You're forgetting about the gravity pull from Scotland into England ??? :wink:
Thread Bear
Re: tzd problems
Slipstream a Ferrari?
I imagine a theoretical estimate can be made of the top speed various BX can hit. Most speedos are designed to ure on the fast side so a reading of a 100 MPH up is probably more likely about 92/93 real MPH. Even that data might be known by the walking encyclopedia on the forum that aid our whims.
BX Bandit
Backslash Bandit
My Cars: Cars
Re: tzd problems
Post by BX Bandit »
:D That's a long way to go for an extra couple of mph!
Tinkley
Re: tzd problems
Post by Tinkley »
You may have seen my comment regarding mph and kph calibration inside the speedo console. This may yet prove to be the cause of these somewhwat theoretical BX speeds... :lol:
Re: tzd problems
What was the actual issue with those new rear tyres? Were they some chepo ditchfinder chinese crap?
BX Bandit
Backslash Bandit
My Cars: Cars
Re: tzd problems
Post by BX Bandit »
Thinking about it, a tzd does 70 @ 3000 rpm, so that's 35 @ 1500 and so will be 105mph at 4500 rpm.....so 105 moh is more or less your max. Where did the 132 come from?
Re: tzd problems
BX Bandit wrote:Where did the 132 come from?
From a looonnng thread on Facebook!
BX Bandit
Backslash Bandit
My Cars: Cars
Re: tzd problems
Post by BX Bandit »
Piff, Facebook........
Re: tzd problems
Post by RxBX »
BX Bandit wrote:Piff, Facebook........
..that_ You've summed it up Neil, (But I call it $hiteface) !
:rofl:
the citroenman
Re: tzd problems
i did put cheap tyres at the time me to blame look mat the man that knows the bx how has the speedo neadle gon to it or do you want to meet up and i will show you it on the 74 go on mat do it if a car on a long down hill desent down pick up a lot of speed over the 100mph lets do it or over members lets get togever to say your wrong come go on some one from this site get in the car to say im wrong go on mat lets do it your not chicken ar you some one has to do it to say im wrong if you dont want to do it your wrong
the citroenman
Re: tzd problems
the owners club now needs come say im full of it you need to get in or ar you all set in your ways me number is 07********2 ring me i will set it up you carnt say im wrong till you do it lets do to shut all you up
