2 years ago is about the time I bought a GKN OS shaft for my TD from them. Had it fitted - and after about 100 miles the boot shifted, got caught in the brake shield and threw grease out. Got it home - and got the guy who fitted it to have a look - now very few miles later it seems noisy - but has gone through 2 MOT's.
Looks like another one or outer joint when I can be bothererd.
Leaves me wondering if these things should be run in? - short runs? My first one was 15 miles down the M27.
Is my driveshaft shafted??
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Well, the part seems ok. Fitting went quite well, although it does 'look' a cheaper unit than the original. Intermediate bearing was also shagged...all loose and noisy (just like an Essex girl!!). The hub nut design is cheap tho'....it has a shouldered nut which needs to be punched into a recess on the end of the d/s to stop it coming undone...
I prefer the spring clip and funny biased lock washer thingy.
All seems well tho, runs ok, nice smooth gear change with new oil, no horrible noises to hopefully all solved.....
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
