Bio fuels
I've stopped using the stuff, but thanks for the info. Is it possible to change from a lucas cav pump to a bosch?
MULLEY wrote: Is it possible to change from a lucas cav pump to a bosch?
Yep, it's fairly straightforward.
You'll need the pump, the pump carrier (cos they are different!), the injectors and the injector pipes.
The boost pipe from the intercooler is different on a Lucas pump too.
But it is all a straight swop.
Ahhhh, a bit more involved than i thought, i think i will stick with what i have for the mo, when fuel hits over £1 a litre then i may go veggie....
