well eventually got a computer running again some weeks later, so to continue...........
Job done, carpet dry, no steam, no leaks . Not the easiest thing to do but certainly helped by all the hints and moral support provided thanks
I found that by disconnecting the clutch cable at gearbox end the pedal falls flat creating enough space, so there is no need to remove the whole pedalbox!!
