17TZD failed indicators/heater blower a few more observtions
simonbx17
thanks
Post by simonbx17 »
thank terry :) well that's shed some light (pardon the pun) on things i will take a closer look at my barrel if need a hand getting a barrel i will let you know. although mine doesn't suffer with dimming lights etc. just that the indicators would stop working last i saw this in a bx it was my dads which was a 17tgd his was the starter motor kept cutting in without warning we would have stop and bang it with a hammer he ahd the Rapido alarm sytem. :shock:
i had a barrel go on my 19 rd but that went the difficult to turn process and then wouldn't turn at all........... :cry:
thanks terry i will keep you posted :wink: :D
Current.
Terry
Location: Tucked up in deeply rural Suffolk away from it all
Post by Terry »
Good on yer,
Terry
Post by Terry »
I went on to say...best of luck...but something cut me off!!
Our Trim Guru
x 13
Post by DLM »
Pleased to hear you got it fixed, Terry.
I suspect my current car's ignition switch is heading the same way: sometimes when it starts the alternator circuit is plainly not switching, and indicators fail to work. Restarting cures this - most of the time.
In cases like this, I suspect it's wear in the electrical internals at the base of the switch that are the culprit, rather than key/lock wear.
Terry
Post by Terry »
Hi
And my thanks for the help. I worked through it step by step, writing down the result of each test, and the more I figured it after the tests the more it had to be that wretched ignition barrel.
I didn't pick up your PM until 48 hours ago because I just couldn't get on the forum, so I couldn't post my thanks until then.
What you're describing sounds very much like the same problem. Funny how there's so many going at once, and I had another on my Landrover a couple of weeks ago. Left the wife stranded 30 odd miles away.
Our Trim Guru
x 13
Post by DLM »
The electrical parts of the switch have to take a lot of use and hence wear - and the components aren't that sturdy.
The mechanical parts of the barrel could be responsible, but until recently I've only ever had ignition lock problems when a key has broken off in the lock.
nstarmore
Post by nstarmore »
I had exactly the same problem with my BX when I bought it but the previous owner showed me that if you turn the key back slightly in the barrel after starting everything works as normal, which may help as a temporary measure as it did for me, something to do with the return spring in the barrel wearing out.
Nic
- 1995 Xantia SX TD (daily hack)
- 1987 BX 16V (project)
