Hi guy's, once again it has been an age since i have checked this, work is busy. Anyways its all starting to make sense, though the passenger side has never worked for the central locking, it works to be activated by the drivers door but not the other way round, guessing that one must have blown before i got it, will have to have an investigation.
Hi docchevron1472, if you are around bristol at all that would be great, but what did you mean by ...... 'I suspect it's more likely to be a break in the wire between the door and A pillar..'? do you mean it might not be the motor?
I work at southmead hospital there and am around most weekends, if you email me on john.thwaites@nbt.nhs.uk if you are thinking of coming to bristol we can arrange something.
Cheers guy's
Central locking
Passenger side does NOT activate the central locking. Central locking is operated by Drivers door or via the ir plip in an unmodified BX.jwthwaites96 wrote:though the passenger side has never worked for the central locking, it works to be activated by the drivers door but not the other way round, guessing that one must have blown before i got it, will have to have an investigation.
Terry Brooks
- Location: No 1 at the end of the bar .....@Milton Arms,Rotherham
Yep ...........my '92 tzd is like that too [it aint got a plip thingy .........it did'nt have one when I bought it]Way2go wrote:Passenger side does NOT activate the central locking. Central locking is operated by Drivers door or via the ir plip in an unmodified BX.jwthwaites96 wrote:though the passenger side has never worked for the central locking, it works to be activated by the drivers door but not the other way round, guessing that one must have blown before i got it, will have to have an investigation.
The central locking on mine works from the drivers door with either the key or with the locking button from inside the car.
Hey Tel, if you can find any BX plip then you can recode it using the info in the BX_DIY pages. Tested this out - it does what it says on the tin!Terry Brooks wrote: Yep ...........my '92 tzd is like that too [it aint got a plip thingy .........it did'nt have one when I bought it]
(I assume the receiver is fitted as standard, the dome like thingy near the sunroof control?)
ellevie
- Forum Treasurer
My 19TXD operates from both doors but both my 19TRSs only operate from the driver's door.
The general consensus seems to be that if you have remote central locking fitted then central locking will only work from the driver's door.
See the following link for more details,
http://www.bxclub.co.uk/forum/viewtopic ... sc&start=0
Also possibly of interest,
http://www.rwbsmith.plus.com/citroen2/plip/
BX19TRS 118K E Reg 1992-2008
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
BX19TXD 150k K Reg
I live about five minutes from Southmead hospital when I'm in Bristol!jwthwaites96 wrote: Hi docchevron1472, if you are around bristol at all that would be great, but what did you mean by ...... 'I suspect it's more likely to be a break in the wire between the door and A pillar..'? do you mean it might not be the motor?
Cheers guy's
The drawback is I'm rarely actually in Bristol unless I'm at work!
I soend the weekends in Stroud.
However, I'm sure something can be arranged.
I'll send you an E-mail!
Terry Brooks
Way2go wrote:Hey Tel, if you can find any BX plip then you can recode it using the info in the BX_DIY pages. Tested this out - it does what it says on the tin!Terry Brooks wrote: Yep ...........my '92 tzd is like that too [it aint got a plip thingy .........it did'nt have one when I bought it]![]()
Nah ......F*** it ........it works with the key ...........a plips just something else to go wrong.
