leaky rear height corrector
Rob_e (UK)
Post by Rob_e (UK) »
Well the new height corrector turned up and I managed to fit it on Friday, in between the hail showers. finished fitting it and it all seemed to work fine. Then just before I took it off the ramps I had a final check underneath only to find the damn thing was leaking again. :evil:
It turned out to be the small length of rubber tube which holds the plastic return pipe onto the height corrector had a very small split in it. I managed to trim off the split bit and put it back with what was left of that pipe. If only I had realised that in the first place I could have saved my self several hours and £76.
Still at least that is one part that shouldn't go for a while.
Thanks, for the help
Rob
BX19 GTi 8v 89 227k
