Any particular brand of diesel engine oil recommended?
ed4ferrets
Yahoo Messenger: ed4ferrets@yahoo.co.uk
Post by ed4ferrets »
Saw some cheapish oil at Lidl today which claims to be suitable for diesel and petrol engines :? . It had an IPA code on it but like Mulley I have no point of reference ... Doh
'94 XM 2.1TD Break
'63 Renault Caravelle
I thought IPA was a brand of ale :D so should i be looking for 4% as a minimum :lol:
:lol: :lol: :lol: :lol: :lol:
Or go the whole hog and get the ballsy 6.8ABV, 10 of them bad mothers and you'll not care what oil your car has in it!
6.8, i like treacle :D I've got my certificate for having drunk a pint of Roger & Out (possibly still the worlds strongest beer?) they would only serve a 1/3rd of a pint at a time, so had to go to the bar 3 times...
Followed that up with a pint called 1066 which is 6.6%, it tasted like water :lol: I then stood up & felt slightly light headed :lol: , not bad for only having drunk 2 pints....
ed4ferrets
I suppose getting well oiled is still on topic :? :lol:
'94 XM 2.1TD Break
1066 is not bad for a beer - some ciders seem to be about 7% or more - much stronger and coins would float!
To return to oil - why not ask what everyone was using when their engine siezed? - In fact I think you will not find any reference on the whole of the site - so these engines wouldn't seem to suffer from lubrication problems - so any oil with the appropriate spec will do an adequate job.
My own BX TD has now covered 207,000 miles (only 18,000 miles to the moon!) and uses a minimal quantity of oil - and the same or less than it did at 1653,000 when I acquired it. Its generally been run on Morris oil, and is now on Total (or did I put that in the ZX?). I tried semi-synthetic but it seemed noiser so I went back to the real thing at the next change.
I can't say that Morris is better or worse than the others as I haven't made a comparison or even run the car far enough to see if its any good.
When my 1946 Austin 8 was burning a gallon every 100 miles or so I used to choose cheap oil by its smell when burnt.
ed4ferrets
jeremy wrote:1
You do a lot of driving in reverse Jeremy? :wink:
'94 XM 2.1TD Break
No - that's the specific gravity!
