Hello from far side of the world :)
Re: Hello from far side of the world :)
Post by ken newbold »
Sound like you might have bought a duff sphere if it's now worse than before.
ken newbold wrote:Sound like you might have bought a duff sphere if it's now worse than before.
not if the rear of the car raises when sitting on the back end with engine off, the sphere should be fine,
constant ticking over a long period of time will damage the innards of the regulator,
so you might be better off trying a replacement regulator
Pogo
Post by Pogo »
What's the best place to get a regulator?
1990 Black BX GTI
barry badger
Post by barry badger »
Did anyone ever get to the bottom of the hissing mentioned at the beginning of this post, one of mine does it and i plan to investigate it later in the year.
1993 tzd estate, on sorn
1992 txd estate, on the road
1991 4x4 estate, on the road
barry badger wrote:Did anyone ever get to the bottom of the hissing mentioned at the beginning of this post, one of mine does it and i plan to investigate it later in the year.
Answered in this parallel thread, I believe:
http://www.bxclub.co.uk/forum/viewtopic.php?f=2&t=18072" onclick="window.open(this.href);return false;
barry badger
Can anyone post an illustration of the ball valve?
Pogo wrote:What's the best place to get a regulator?
depends if you mean re/con or second hand,
try Martin at Pleiades for a re/con unit on
01487 831239
email
[email protected]
Pogo
Post by Pogo »
Thanks, I think maybe go up to Plaides and let them have a look might be an idea.
I generally hate taking a car to a garage when I can do it myself, but changing parts without really knowing what the fault is will be more expensive in the long run.
1990 Black BX GTI
Pogo
Post by Pogo »
Well spoke to Matin today, he thinks it will be the pressure valve, (Which he keeps in stock).
He can test it if I take the car up, or he could post one and I could just try it.
I've decided to take the car up and get it looked at by them, that way he can advise/repair anything else that needs doing.
It will be more expensive, but I want the car right.
1990 Black BX GTI
