how to change the starter motor ? can you help ?
cauchoiskev
cacaolat
Thank you mat and M, I will happily come back to these kind offers. Of course first I have to check the leads and make sure the starter is the right kind. tomorrow I am busy, and in the evening it is dark already !
by the way jonathan my first car was a GS special (1979)
jonathan_dyane
Indeed, I guess we all are anachronisms in a way, driving and (generally) fixing ourselves old and somewhat eccentric motors, but I guess we have the last laugh.
I can't remember the answer to the Derby question, which is probably just as well.
Cacaolat: excellent choice of first car
cacaolat
I have checked the negative lead by attaching a jump lead between battery negative and engine bits. No still the same so I will have to change the starter motor I suppose
Is this just a matter of unscrewing the bolts and disconnecting a couple of cables, or is there anything more mysterious to it ?
can anyone tell me if one of the 2 starter motors offered above would fit my bx ?
And more I now have the feeling that I really need to do this relay conversion... anyone has advice on this ?
http://bxclub.co.uk/forum/viewtopic.php ... +australia
mnde
- Meteor Man
Hi Gregor,
You may have better access to the bolts as yours is auto. I believe they're Allen or hex bolts. AA man changed one on the drive once (BX #1, now RIP) as part of Home Start (brave bugger; it was raining too). And he had a right pain with one of the bolts because the clutch arm was right in the way, even with clutch fully depressed, so he ended up tapping it round with a long narrow drift! Nothing mysterious to it I think.
Good luck!
Mark.
Good luck!
Mark.
velosolex50
Hi. I have a 1.9 tzi auto, and the starter is a pain to do on that because of the huge inlet manifold covering it up. No clutch arm in the way though.I think it is ok on a carburetted car. 3 allen headed bolts (tight! you will need decent socket set type allen tools) , the main power connection to the solenoid, and 1 other normal size wire connected to the solenoid if I remember rightly. I have just changed the starter for the same symptoms, and found the new one to be no better. I would try the relay wheeze first, as it might just save the price of a starter. I am going to try it when I can get to it. Good luck, its no fun having no starter in an auto!
Huw
Huw
cacaolat
Thank you I will thoroughly investigate the relay conversion. I have read the thread above, but it would be useful to see some photos or the exact relay I have to order...
Tomorrow! first thing in the morning I will buy my own multimeter to double check things.
(half price from maplins) http://www.maplin.co.uk/Module.aspx?ModuleNo=44679
then I'll plan my repairs
I'm a huge fan of Hitchcock, love the 39 steps, and have a piccy of john Buchan on the wall (dont ask)..cauchoiskev wrote: Jonathan, wake up this is 2009, nobody has ever heard of the 39 Steps, or John Buchan, or Alfred Hitchcock for that matter. And they call films "movies". And nobody drives in BXs either.
and I'm only 28!
Never heard of a BX though...
cacaolat
I wanted to double check the resistance measurement, with the new multimeter I bought. I am having problems getting the digits to move at all. It stays at 1.
I tried it with the ignition on and off ?! is the new multimeter not working properly ? how can I test it. The instructions are minimal and not very clear.
On top of that it is too cold out there to work on the car.
cacaolat
will this fit the BX 16 ? just in case you are in the know, would be happy to find out.M wrote:I have a known good starter motor off a 2.0HDi, no idea i it will fit, but if it does you are welcome to it for gratis.
I would get another one but Mat is on Holidays.
1 signifies that the resistance measurement is higher than the range that you are switched to or is open circuit.cacaolat wrote:![]()
Check that the meter is working by touching the probe tips together and the meter should indicate 0. If it doesn't, you have a wrong setting, fault or have burnt out internal components of the meter by trying to measure resistance with voltage still applied across the measuring points.
cacaolat
Way2go wrote: Check that the meter is working by touching the probe tips together and the meter should indicate 0. If it doesn't, you have a wrong setting, fault or have burnt out internal components of the meter by trying to measure resistance with voltage still applied across the measuring points.
I have just touched the probe tips together...it shows changing numbers between 1 and 45. at one stage it actually displayed 1.3 for a while ?
I hope I did not break the thing.
I just measured from the cars -terminal to the starter motor. The battery was still connected, or was I supposed to disconnect that ?
With the other meter (returned to shop) I was a bit more experimental and I tried to measure even with ignition key on and on the + terminal, but this time I was more careful.
- BX Digit man!
Where on the starter motor? There are at least 3 different terminals on the solenoid. You are looking to measure the resistance across the windings, which can be done by measuring between the copper link and the body of the motor.cacaolat wrote:I just measured from the cars -terminal to the starter motor..
cacaolat
