TXD turbo?
demag
Dunno about that, but the reverse is true.
- Our Trim Guru
Oh good god no, it would barely move!demag wrote:So just out of interest I think Kitch mentioned a difference in the cams. What is the difference? Would fitting a turbo cam to an n/a give it more power?
The turbo cam dont open the valves as far or for as long, so fitting a turbo cam in an N/A would result in the slowest car of EVAH.
Fitting an N/A cam in a TD though gives a nice increase in off boost torque, and a noticable bit extra on boost.
- x 25
demag
- x 25
Ahhh,
er, well, alot of it depends on driving style really.
Off boost economy is improved, only a tad mind, but it is slightley increased as the engine breathes better off boost with the N/A cam.
On boost though economy can be a bit worse since the ability for the engine to move air is increased a bit, and therefore if you drive like Michael Schumacer then it'll go a bit better, but economy will of course suffer.
As is always the case, you rarely get somehting for nothing!
Its negligable though, all in, the advantages far out weigh any tiny disadvantages.
- x 25
- x 25
YorkieTXD
well i changed the air filter oil and oil filter. the other thing i did is put super diesel in it. That has definatly made alot of difference. I am now however aiming to drive economically, as i only got 420 miles out of 52litres last month. avg MPG 36. however this was mainly urban and alot of hills. so not too bad i suppose.Roverman wrote:The 1.7TD and 1.9TD engines are quite different to their non turbo counterparts, they are strengthened, have different cylinder heads, gearboxes, cooling systems, exhaust etc etc. I would try geting it serviced and set up properly and if its still not fast enough maybe swop it for a TXD/TZD turbo as it would be far cheaper and easier.
Welcome to the forum and keep us updated to see if the service helps, my friend recently bought a 1988 19RD and it was woefully slow, a good service, some injector cleaner and good long runs with the "taps open" has made a HUGE difference.
Current 1993 19 TXD White
Previous 1988 19 Rd
Previous 1988 19 Rd
