loss of water in the radiator!
Rgod wrote
"but the oil cap,were we fill oil was like mionz,white"
if your crank case breather is blocked you will get mayonaz in the oil filler cap, as this cause's condensation,
Rgod
Post by Rgod »
OK the loss of water had gone,but now the fans start to work when i turn on the switch,at low speed ,sometimes doesnt ,suggestions?
Rgod
Post by Rgod »
hiii ,my problem got back and now i have bubbles in the rad,when i start from cold,and it gets warm very fast and the vent doesnt goes on ,the water level is ok before i start to ride what to do ?
Post by kiwi »
You replaced the thermostat in the engine head?
Having problems here trying to understand what your troubles are?
Are you talking about the INTERIOR heater fans?
AdrianO
Post by AdrianO »
Interesting that no-one has yet considered loss from the water pump. Though I once drove a Fiat to Spain and back with a leaking water pump, I've been driving a BX's for 15 years and never had or heard of BX's having water pump issues - maybe this item really is totally robust?
I mention it as I need a timing belt change, and my man mentioned possibly replacing the water pump. So I came here to look for water pump issues, but the forum search seems to not be working just now.
My understanding is that seeing as they are so cheap off e-bay to buy, as a precaution they are worth changing even if the old one looks to be ok.
Post by kiwi »
AdrianO wrote:Interesting that no-one has yet considered loss from the water pump. Though I once drove a Fiat to Spain and back with a leaking water pump, I've been driving a BX's for 15 years and never had or heard of BX's having water pump issues - maybe this item really is totally robust?
Funny you say that! As a matter of course it seems that NZ mechanics will replace a water pump when they replace a cambelt.
Post by Mothman »
Rgod wrote:hiii ,my problem got back and now i have bubbles in the rad,when i start from cold,and it gets warm very fast and the vent doesnt goes on ,the water level is ok before i start to ride what to do ?
I reccon your head gasket is a problem. Is the cooling system pressurised when cold? If it is then its the head gasket for sure.
Yep me too, I'm afraid not mentioning it won't make it go away! bubbles in the coolant straight away + rapid heating points to combustion gases in the cooling system, time to do a pressure test my friend.
