17 TZD Engine starts fine but peters out after a few seconds
andycadabra
Thanks Mat. Well, I managed to get the star washer off easily in situ, but couldn't get the white plastic thing out at all, and there was little to grab onto. Then I thought of just leaving it in and trying a bit of 'sealastic' non-setting sealant, but having put the sealant in couldn't figure out how to get the star washer back on.
Then luckily found a piece of pipe that fitted in the recess perfectly, and putting a hole through its diameter allowed me to strap it tightly to the fuel filter housing, and everything seems fine now, no more random revving either!.
The fact that the fuel intake to the fuel filter is at the bottom, and the outlet is right at the top seems to be a recipe for disaster should any air find its way into the fuel filter. I would have thought the positions should be reversed, but there's probably some good reason for it!
