so what sort of ride hight correction does the pug have for its rear end,
i had always thought these pugs had just a BX rear sub frame,
Possible to make raised suspension softer??
2 reasons spring to mind - 1st, even hydraulic suspension on the rear only makes for a smoother ride, which is why some H van ambulances were built this way.I really don't understand the logic of a hydraulic system just for the rear of a 405? why not use conventional springs?
2nd, from PSA's point of view, it was probably easier to base a self levelling rear suspension on technology they already knew about than to use a self levelling shock absorber system like the ones used by BL on the SD1 & Range Rover & Ford on some Sierras. Anyone who (like me) loads their cars up with heavy gear regularly knows how much better any self levelling system is in these conditions.
Ok, its smoother riding, but there are plenty of 2wd 405's that only have springs, so why does it matter with the 4x4? Thats the bit i don't understand, surely the 4x4 system doesnt mean that it only works with rear hydraulic suspension & surely the standard front springs mated to a hydraulic system at the rear make the car extremly unbalanced from a suspension balance point of view?
adriches
paulwitchard
The BX was apparently known to HM Customs and Excise as the 'bootlegger's friend'.
Paul in Normandy - BX 1992 Millesme 1.9D, 1999 Peugeot 806 2.1 TD (the Bus) - gone bang on the M25, in a scrapyard somewhere in the SE of England, 1985 Visa Decouvrable, 1990 Land Rover 110TD (Great Uncle Bulgaria),1999 Isuzu Trooper, 1991 Hymer motorhome with Peugeot J5TD power, and a shedfull of mopeds!
Stinkwheel
Naaahhhh, that was a CX safaripaulwitchard wrote:Anyone who (like me) loads their cars up with heavy gear regularly knows how much better any self levelling system is in these conditions.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Tis true, I've been stopped twice in my diesel at customs, and both times was told they are the best smuggling car in the world.
Having watched exactley where they looked in and under my car I now of course know exactley where to stash all those illicit drugs!
Odd thing though, I got stopped on the way TO France both times, never on the way back..
- BXpat
Doc wrote
How about a sticky - 'Where to hide drugs on the BX?'
C'mon a little more detail please! Where the rear subframe mounts are is a good place.Having watched exactley where they looked in and under my car I now of course know exactley where to stash all those illicit drugs!
Well, in the heater box, in the body kit, under the rear seat, in the instrument binnacle, above the glovebox, int he centre console are but a few places I noted they never looked.
But they did take my bass bin to bits to have a look in there, and then broke it.
About 14 years ago IIRC customs were stopping quite a few 2CV's coming back from the Dutch world meeting. Apparently at the time 2CV's with aftermarket galvanised chassis were being used for smuggling as you could unscrew the bottom chassis plate in order to fill the space between the rails with watever you were bringing in.
rayfenwick
I don't know about you guys, but this reads like porn to a geek like me...Kevin B wrote: Unlike the suspension system you would see on a BX 4x4 this system is somewhat more complicated than exen the BX.
On the non 16V Peugeot 405 4x4 the ride height is controlled by the position of a variable resistor which is connected to the anti-roll bar, by a plastic link which is able to pivot. Somehow this resistance value is then transmitted to the dedicated 12V hydraulic pump mounted on the rear subframe, depending on the position of the antiroll bar.
Ray
www.citroencarclub.co.uk
christhelion
I looked this up a few months back out of interest and the subframe looks the same as mine but with some added axtras, as you all say.
A mate told me they had something in the boot or something that can move the ride height? Is that right?
1992 BX GTi 4x4 in silver with all the extras. (sold and missed)
2000 Kawasaki Ninja ZX-9R E1
2000 Gilera DNA 50
2000 Ford Focus 1.8 Zetec
2009 Ford Focus ST-3 225
Borrowed 2006 Kawasaki ZZR 1400
2000 Gilera DNA 50
- x 94
The rmain reason they had the hydraulic rear setup is to keep the rear end at a constant height to reduce wear/stress on the rear drivetrain like the CV joints and diff, while also maintaining normal ground clearance whilst loaded for climbing every mountain and fording every stream and so on....citsncycles wrote:2 reasons spring to mind - 1st, even hydraulic suspension on the rear only makes for a smoother ride, which is why some H van ambulances were built this way.I really don\'t understand the logic of a hydraulic system just for the rear of a 405? why not use conventional springs?
2nd, from PSA\'s point of view, it was probably easier to base a self levelling rear suspension on technology they already knew about than to use a self levelling shock absorber system like the ones used by BL on the SD1 & Range Rover & Ford on some Sierras. Anyone who (like me) loads their cars up with heavy gear regularly knows how much better any self levelling system is in these conditions.
