As a layman, how much damage does carbon do to the engine? I thought it too was pretty slippery stuff?smiffy1071 wrote:I'm with David on this, Diesel engines will produce more soot/carbon deposits (which is why their engine oil goes black so quickly after a change).
This carbon floating around in the oil will cause premature wear if left in there too long.
Just on that basis alone, I'd rather use cheap oil, and change it more often.
I can understand if it builds up in large chunks ie in days past a decoke was a regular need but with all the detergents and additives in todays oils isnt it kept in suspension within the oil?
I only do about 3 k a year so i change the oil only once a year.
