Still there and worse! I can now stall it by opening the throttle fully in neutral. It revs hard, then drops to 2500 or so, spluttering and popping, revs gradually dying. After a few secs it cuts out. Struggles a little to restart but does and idles fine. If I release the throttle during the spluttering stage, the revs drop to idle and it ticks over normally.
So I am convinced it's spark rather than fuel. It feels like it's running very very rich whilst my foot's on the floor but the fuel isn't igniting, hence why I think it's spark (or, lack of spark!).
I would happily rule the spark plugs and HT leads out. I would think if one were faulty, it would only misfire on one cylinder but this is across all 4. I already changed the main HT lead (king lead? From coil to dissy) so that's ruled out now too.
So that leaves coil or ignition module.
Yeah, about that ignition module and it's location, I know people have said it's under the inlet manifold but really I don't see it. I did find a module which looks like the thing, located behind the battery on the bulkhead on the left side of the car. Don't forget mine is LHD and I don't know if that would mean it gets a different location from you RHD chaps.
