My Cars: 1999 Xsara LX 2.0HDI (90) Hatch - Fern 2002 C5 2.0 HDI (110) Estate - Jasmine - SORN 2011 Mini Cooper D Clubman - SOLD 2016 Mercedes A180D Sport - Auto refinement 1992 TZD Turbo - Bluebell - SORN 1992 TZD Turbo Estate - SORN 1991 Gti 16V - Blaze - crash damaged, will get repaired - SORN 1990 Gti 8Valve SOLD - looks like it's been scrapped 2002 Mini Cooper S - SOLD - i miss this car 1992 TXD - Scrapped in March 2014 1988 CX 25 GTI Turbo2 - SORN 1996 - AX Memphis 1.5D - Dream - SORN
Postby MULLEY »
Done it It would appear to be connected to the brakes, as i noticed the lhm surging through the filter when i pressed the brake pedal. It would appear to be picking up some gunk already, so thats good news & it would appear that the flow rate is quite high so it should clean the hydraflush & hopefully avoid too much dirt/scum getting into the main lhm tank.
I fitted it in exactly the same spot as the other lads, i've used a smaller filter, so if that gets very dirty i'll try changing it for a larger one. Was a bit of a pain getting it to stop leaking, but with some fiddling it would appear to be leak free for the mo, i'll check it daily & i might re-position the filter if the leaking starts up again, it might be a bit close to the lhm tank & so is putting a bit of pressure on the hydraulic pipe that normally is fitted to the tank.
I'll report my findings as i go along.
