breaking bx 16v in nearly mint condition
cossieboy599
Post by cossieboy599 »
Front wings. O/S is mint with arch spat, N/S has small dent in top tip due to someone losing their rag with it!
dont no who that was lol
like kitch says he is sortin the car out cause i had no storage the shell will be gettin scraped unless someone does want it he is stripping it so donations to him for stuff should be sorted seeing as time is money after all.
the wheels are wanted i have had a offer already on them which is fine for them so there sold
i no someone wanted some corner pices i think just let kitch no and we can go from there
Right wheels are sold now.
Had interest in the read doors, vented brake setup, height correctors, FDV, struts etc already.
If you want something move quickly, theres been way more interest than I'd guessed!
Kitch wrote:Right wheels are sold now.
And the left ones too I hope! :wink: :lol:
The left ones are square, but I'll throw em in on the deal :wink:
Backbox has now been claimed.
Parts claimed:
Alloy wheels: Mr Chidlow
ARB's and links: Arse-Bandit
Front brakes/ABS stuff & struts, height correctors + links, FDV: Mulley
Rear window motors/regulators/switches/wiring bits: rhv100 (unconfirmed)
Sunroof cable track cover: way2blow
Everything else still available. Interior has been removed now and will be listed on ebay if no interest here. It really is tidy!
Tailgate is off. Slightly chipped in the process sadly (heavier than they look!) Spoiler won't come off!! But tailgate comes with ABS badge - result!
Carpet looks good. Car was leaking like a sieve though, so all the sound padding etc is no good.
On the car....boot floor is like cheese. Inner wing on the OSF has broken up too, the bumper mount has totally vanished!
Sad bit is that the rest looks tidy and well held together. Someone up until as recent as a year or two ago really cared for this car. But it would have needed welding, so I'd say the shell's a scrapper.
Matt H
Post by Matt H »
Ahhh... just my luck not to check the forum for a few days!
PM on its way
Aerodynamica
Post by Aerodynamica »
Is the car being broken or is someone getting it whole?
If parts are up for grabs I'm after the tailgate struts if they're good!
Graeme M
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
'c'est hydropneumatique'
Its being broken up for parts, if you look a few posts higher up there's a list of whats already gone, be quick :D
djoptix
Post by djoptix »
I'd have the rear subframe but I'm too far away. If anyone is doing a parts run and bringing things back to the Midlands (Herefordshire/Worcs/Gloucester way) then let me know...
As I've mentioned already (I think I did!), rear suspension is a bit of an issue as without it I can't roll the car out of my garage onto a truck. I'm supporting the front with an engine crane, so the front is coming out and going to Mulley. Back....unless anyones got any ideas we're screwed!
PM's replied to.
Matt H will want the rub strips and possible drivers door and tailgate, plus the black interior bits (although note David. R was after the clocks...I'm guessing he'd be happy to split them from the clocks?) He may also want the carpet.
rhv100 has confirmed he wants rear electric window setup, so thats gone. He may also want sunroof setup, although cable cover is possibly going to way2go.
Le Mans interior still up for grabs. I'm gonna try and keep the doseur valve and fogs myself.
Rear bumper is still available!! sale fell through (lack of contact)
Front bumper has good red strips, and is good overall but needs some fibreglassing.
Interior still here and looking mint.
djoptix
Post by djoptix »
No worries Kitch, I was assuming that it wouldn't happen - unless I come up with something at exactly the same time as you're scrapping what's left of the shell! :)
Kitch wrote:although note David. R was after the clocks...I'm guessing he'd be happy to split them from the clocks?
All I'm after is the unit with the speedo, tacho and 4 other dials. None of the plastic trim, dashboard or anything else like that. Ta.
thanuttiscotsman
Post by thanuttiscotsman »
Kitch wrote: I'm supporting the front with an engine crane, so the front is coming out and going to Mulley. Back....unless anyones got any ideas we're screwed!
why not bring the car needing the bits and the donor together and do a straight swap?
1996 transit 2.5di 80 swb
djoptix
Post by djoptix »
Not a bad idea in fact! But I need to do all the hydraulic pipes while the subframe is off too...
