But Mr Dyane, you do indeed 'need' a valver!
BX turbo diesel wanted
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
- x 94
If it was a stock valver, it wouldn't go that far into the red
Mine does with just the chipped ECU, goes up to 7800rpm but personally I think it peaks at 7400-7500rpm. The standard bottom end can take 8k I'm told, although a standard head is only really useful under 7.5k revs.
When he shifts up he's not far above the red, but if it#s chipped the whole power band has probably moved up too....doesn't wake up until 4800rpm.
I think Doc will need to drive BAH on saturday....I need some comparison
I dunno if it's pant or not!
Oohhhh, go on then!Kitch wrote:I think Doc will need to drive BAH on saturday....I need some comparisonI dunno if it's pant or not!
It certainly seems to go ok from the various vids I've seen of it.
And it should go better than mine as I binned the chipped ECU and stuffed a stock ECU back in the old girl.
It feels much flatter now, but I'd rather keep the con rods inside the block longterm so it can stay flat!
Tourist
I've got a nice Gti 8 valve that i'm thinking of selling. PM if you're interested.
SamWise
Have you noticed he's been quoted £1200 insurance on a TD, and that's if he claims to be a student, otherwise it's £2400. Can you imagine the premium on a GTi?
1966 Triumph Herald convertible with big valve twin carb Spitfire head
1973 Bedford Panorama Elite II Bus
1994 2.1TD Citroen XM
1992 Citroen AX Echo 1.4D
Tourist
