spent a while thinking about all this while having a soak in the tub last night,Does the acc. sphere affect ride? well actually i think it could the acc. sphere is in the system to do two things 1 is to provide the system with a constant pressure ie the pump charges the accumulater which in turn delivers the pressure to the system thereby eliminating any wild fluctuations .2 is to store pressue so it the event of pump or more normally belt failure there is enough left in the system to allow for the brakes to work and get the car stopped safely.
Suppose you had a duff accumulator or even a weak one ,combine this with a weak pump or even a loose belt this means that the pump is working harder to provide the required pressure to the system (hence faster tick times as the pump is constantly trying to keep up the pressure in the system) this then will affect the system as it is not opperating at its optimum pressue.
Now i could be talking b******t but it did sort of make sense to me ,but i am happy to be shot down in flames and told to go back into to the board of many drawings!
Max i still think another dose of hydroflush will not do your beast any harm and getting that height corrector changed will help.
Geoffrey interesting ideas about the struts i will experiment with the ones from maxs car i have two repair kits here (under lock and key
) if you want to know the contents, cannot help thinking that like the rear arm kit most of it will not need replacing .
Well thats my tenpence worth for today!
