Also fitted some brand new bosch wiper blades, a 19" & a 26" one, £12 off e-bay which i thought was a fair price for good quality one's. Again, what should have been a simple task ended up taking a lot longer, i tried putting the sweep on to get them central to make the job easy, but with a C5 it would appear that even with the ignition switched off, they return to their correct position
There were also some little tabs in the roof rail guttering which should be flush which weren't, so i removed the trim & re-positioned those to cover the bolt holes should a roof rack be fitted to stop shit getting onto the threads.
Spotted some bodgery with driver side rear indoor door handle, i wondered why the door handle trim wasn't fitted, which upon checking would appear to have the important tabs broken off it, arrrgh. It may be easier just to buy a 2nd hand interior door handle again. The interior has really taken a serious battering by the previous owners, i think it was used for skip carrying duties, does drive well though.
Also noticed the plastic engine cover grommets had become unseated again, so i'm going to order 4 new one's from e-bay, but a superior looking alternative to the shite plastic citroen one's. I've been warned about this cover, when it comes loose, it can wear out the shitty little coolant bleed nipple which then means catastrophic engine failure, it's one of the most stupid design faults i've come across, so this will get sorted sooner rather than later. I've not calculated the latest mpg, but the last tankful i got approx 46mpg, which i suppose for an extra large barge isn't bad?
