Mulley's New 19TXD
- x 6
Re: Mulley's New 19TXD
Only the conical gasket at the manifold to front pipe needs a short bedding in period. The wire just settles down with heat and pressure from the two bolts. Mine was blowing slightly at the MOT (yes I could hear it) but passed as it had only had 35 minutes running since fitting (running flushing oil through) but later it settled down much quieter. The main cans should be fine. Always possible there is a pattern one with different pathways for the gas. Also the steel type can give a different harmonic resonance and you will of course be used to the old one.
- x 8
Hmm, i'll monitor it for a bit & if its still to noisy for my liking i'll get it inspected to see why.
- x 8
This saturday David & his mate collected K743 NVL, i managed to salavge the battery, hydraulic pump, both the fronts & rear spheres, couldn't get at the accy sphere. It was a bit sad to see the car going on the back of a trailer never to be seen again, i'll just have to remember the good times that i enjoyed in that car. At least David will use parts on his & anything he doesn't need can help other cars in the future, much better than being crushed. Bye Bye, i think i'll keep my avatar for a bit, or until my other 2 BX's become roadworthy.
1985 CITROEN BX 19GT C1TBX
I share Paul's sentiments, hopefull this will spur you on to get the TZD turbo up and running again
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1991 BX 19TZI Auto A/C
1994 Xantia 1.8i SX
1972 Morris Marina 1.8 SDL
1979 Rover SD1 V8-S
1980 Morris Marina 1.7 HL
2003 Rover 25 1.6i XL 5 DR
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
- x 8
Just waiting for Shaun to come down & hopefully bluey will rise again
- x 16
It's ironic - no progress on it for years but after a couple of weeks with a C5 there's a plan to get it back on the road
- x 8
There was a bit of progress on the TZD last year, managed to get it to fire up after the cam bearing cap & damaged camshaft were replaced, still needs a few bits doing such as the cambelt & the electrical issue which is stopping the starter from turning over. We'll have to see how much rust is lurking etc to fully evaluate what needs doing, fingers crossed
