It's been a while, so I thought I'd bring you up to date on how the Hurricane is following its exertions in France.
It ran very well, although, at altitude (we're talking 3,500' up to as high as we went, nearly 7,000') the lack of oxygen meant not all fuel was being burnt so it was quite sooty under load. Although the car has had a relatively easy life over the past several years, I really pushed the car to its limits. It responded well and loosened up nicely. The poor old wheel bearings though... front o/s needed replacing halfway round and the o/s rear is well grumbly so that's going to be done too along with both the n/s ones.
Here's the list for the Spring...
As mentioned; New O/S front wheel bearing fitted (SKF part).
Tracking done.
To do:
Replace N/S front wheel bearing (SKF part available).
Replace both rear hub/bearings (QH parts available).
Stainless steel fixing screws are replacing the old ones all round.
Replace rear calipers and pads (Xantia ones and EBC pads available).
Replace rear discs (and dust covers possibly, but this is tbc).
Replace O/S caliper (have Bendix part available) if any issues with handbrake (slack return spring).
Poss fit new front flexis and new HP brake pipes both sides. If so, locate and fit new N/S caliper* -Tricky!
Fit new Purflux fuel filter (might as well, I have a new one here).
Touch up paint on door and on alloy. (Some paint came off the door - and I might go the whole hog and get the door repainted)
Mop and polish plus interior valet.
Repair small hole in rear passenger footwell floor (non-structural).
Rev counter intermittent - investigate (and live with it probably!).
Warning lights issue addressed but need expansion tank sensor plug - eventually.
So that's enough to be getting one with.
Talking B____X
- x 25
Re: Talking B____X
- x 174
- My Cars: BX GTi, C3 Auto
- x 96
Re: Talking B____X
Thanks for the update Phil. I wondered how you all got on.
I am surprised by your comments about running at altitude because with a turbo I imagined that this would compensate for the thinner air. My petrol GTi certainly struggles for performance over the cols but my modern turbo diesel is not affected at all.
I am sure all BX owners have a list like yours of things to do. I too have a rolling list of waiting jobs and I know some of them will never be done.
Here is my current one from my BX spreadsheet going back to last year:
Check tank outlet filter
Mod spare throttle housing
RLH light leak? done 2.19
Dash rattle LHS + RHS
SQUEAKS RH xxxx see below
LH driveshaft seal done 10.18
AntiFreeze
Pump belt tensioner change done 6.09
Comp check ???
A/C belt done 6.19
Fit a/c chargingValve
Aircon regas
LHindDashBulb done 10.08
clutchCableSqueak done 10.18
Sunroof adjust
waterLeakRearSeat 9.18 tubes cleaned
Seal inletManifold done 10.18
Bleed rear brakes done 7.19
swap injectors
weld rhboot side done 6.19
LH steering gaiter done 7.19
fix interior lights 2.19
replace rad temp switch done 11.18
HeadGasket?
WeldSilencer done 2.19
PR leak done 11.19
xxxx FRH suspension noise
petrol smell
Accumulator done 9.19
Battery/alternator done 9.19
thermostat
Front LH air deflector on brake caliper
AntiFreeze
Comp check ???
A/C belt done 6.19
Aircon regas
Sunroof adjust
swap injectors
HeadGasket?
PR leak done 11.19
petrol smell
thermostat
- x 25
Re: Talking B____X
Well, a combination of driving hard and altitude seems to have caused sootiness as, when back closer to sea level it was much less sooty even with the foot to the floor. However it might be a sign of overfuelling? in which case the new Bosch injectors could be fitted replacing the old, original Lucas ones. But having said that the car's going well. And there was very little sign of smoke or soot before I went away.
1987 Citroen BX 17RD - x 105
Re: Talking B____X
Air is thinner at altitude so that's going to make it run richer, since you'll have more fuel to your air mix, I would expect. So back at regular altitude, the sootiness would clear up and your fuel-air mixture would be more normal.
- x 25
Re: Talking B____X
Well, I finally found a front left (n/s) caliper that matches the refurbished Bendix one I have for the other side. Twas tricky to find, but got there in the end.
Now, all I need is for Kermit (aka Phil Boxall) to strip the relevant bits from the rear of his Xantia (discs, calipers and pads) make the trip over to me and fit them along with the new hub/bearings I have (Then we'll need to address the front brakes - I have new flexis and HP pipework ready as well as calipers).
Whilst we're doing this work on the rear, I was wondering if anyone had spare/refurbishable dust covers for the back of the rear wheels? Mine look a bit knackered!
