Alternator Belt
Alternator Belt
Battery light came on today from work after i'd stopped at inlaws. Not sure if its popped off or just snapped, in the limited light of the cars headlights i couldnt see it dangling, so presumed its gone....
Anybody know what type i need for a 1992 TXD please?
And are they easy to fit? some instructions would be great.
Cheers guys
Post by ken newbold »
Standard 4 groove belt, a piece of p155 to fit, even at the side of the road :D
I'm presuming access is underneath car & that there's nowt in the way for me to just pop a new belt on?
Don't presume nuffin :lol:
Access is from above, you'll probably be able to manage with just a 10mm and 13mm spanner, but sometimes the alternator mounting bolt is tight and then you'll need a 21mm I think :?
ed4ferrets
Yahoo Messenger: ed4ferrets@yahoo.co.uk
Post by ed4ferrets »
Is the answer the same for a TD or are there many more obstacles :?
'94 XM 2.1TD Break
'63 Renault Caravelle
jonathan_dyane
Post by jonathan_dyane »
ed4ferrets wrote:Is the answer the same for a TD or are there many more obstacles :?
Yes it is the same, and yes there are more obstacles ;-)
Taking off the plastic duct that goes from the air filter to the rubber piping on the O/S inner wing may be a help...
Typical, slightly more involved than i thought. I'm sure i can work it out in daylight, but really wanted the car back on the road before then. I'll take it to garage as i want them to investigate the continued knocking sound from the front of the car, after the recent strut replacement anyway.
I rang my local GSF branch today, to order the belt & a few other bits, funnily enough their prices were more expensive than the website, so even taking into account the discount i could have got, travelling to them with the higher discounted price, it worked out cheaper to order the stuff online at the full cheaper price with free delivery.
Thats odd, surely if it's an advertised price they're obliged to sell it for that price?
The sheffield shop said that the website wasnt anything to do with them, so well worth having a look online 1st, then phone up your local branch to see if there's any difference in price. The free p&p was the clincher to this deal for me, along with the cheaper price....
New belt fitted, i can now drive car again :D Garage couldnt find any problem with the suspension, its still making the same clonking sound before the strut change, however the ride has improved with the replacement strut, so unsure if its the strut or not.
No noise when driving straight ahead, unless going over speed bumps at 20+mph, no noise when turning right, but seems to make the noise when turning left over bumpy terrain (sheffields roads).
Garage even took the car out for a spin but couldnt replicate the noise, should have gotten them to drive to sheffield, couldnt fail not to hear the clonking sound.
Could it be subframe bolts loose?
Strut again?
Caliper?
Any other suspension components that dont appear to be knackered by either looking them or moving them by hand/bar, but are shagged?
Any suggestions ideas greatfully rec'd, cheers :(
N/S droplink if I were guessing.
Yes it could be the subframe bolts, they do come loose from time to time and VERY easy to check.
Cheers Ken, might nip over to garage tomorrow to see if they can check those 2 items out. Just out of interest, is there anyway of telling if the droplink is knackered by looking at it, or is it when it starts clonking thats the only way?
The drop link is checked by giving the ball joint at either end of it a nudge with a big bar, if there's movement ecident it'll be on the way out.
One thing to check is the stering rack.
I had an iritating clonk from the N/S suspension for ages, everything was replaced, even the driveshafts, and still it bloody clonked.
Ignored it for a while then it started getting worse, purely by chance I was changing the gear oil and pulled myself under the car on the TRE.
There was an alarming amount of movement, so I gave it a good tug, and low and behold the clonk became evident. The big bush the rack moves in has broken up.
/never seen it before so it probably isn't that on your car, but it's easy to check. Alas changing the rack is a bit of a faf but I'll get to it when the weather improves. In the interim I have the other car!
Cheers for the info doc, i'll get garage to check the drop link as per your advice. Lets hope its not the rack, i'll get them to check that if all the other options have been exhausted.
It's unlikely to be the rack, they seem to last forever, I'm not at all sure why mines carked it TBH, although it is original and has done not all that far off a million miles since 1989 so I cant complain!
