Hydraulics and suspension question
Leapfrog
Post by Leapfrog »
Hi,
I am thinking of buying a 1990 BX TZI Automatic and have a couple of questions to ask. I have never owned a BX before and was very impressed with the performance, handling and ride of the car when I took it for a test drive.
One problem is that the rear of the car makes a very loud creaking noise as the hydraulic suspension is raised. What is causing this noise and is it a major problem - as I say the ride is extremely comfortable when moving but the creaking noise on initial pumping up of the suspension is worrying me.
Also, when the ignition is turned on there is an alarm sound which goes off as the suspension is pumped up and stops when the suspension is at the correct ride height. I have seen start-ups of BX's on Youtube and none of them made the alarm sound. Is this a fault or, as the owner says, just a warning to not drive off until the suspension reaches its proper height. If it is it an alarm can it be disconnected?
Your comments would be appreciated
Aerodynamica
Post by Aerodynamica »
Hi and welcome!
I think the creaking noise you've been hearing will be the notorious rear suspension trailing arm bearings. These can be repaired fairly easily by the DIY mechanic with fairly good facilities. The bearings themselves (two per arm) can be bought from GSF and Euro car parts. If it's to be done in a garage it'll cost over £200 for the labour (maybe more?)
As for the alarm: not sure myself - usually it's only a big red STOP warning light that comes on before the hydraulics are all pressurised. Having said that: I believe that Australia market Citroens had a warning siren for the hydraulics in addition to the light to meet the Auz requirements - are you in Australia or UK or where?
Graeme M
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
'c'est hydropneumatique'
DLM
Our Trim Guru
x 13
Post by DLM »
Nothing whatever to do with the hydraulics, I'm pretty sure. This sounds like the rear-arm bearings need replacement, and is a definite bargaining point . Repair kits containing all the parts for the bearings are £30-ish a side - though the repair may become problematic if this job has been left too long, as the bearing housings may become damaged.
The normal giveway is that when the suspension is set to full height (maintenance-only setting), the rear wheels lean inward when viewed from the rear like so /--\ as opposed to a normal upright position |---|.
This doesn't always happen - the needle bearings can corrode in their cages - and both could start to break up without the characteristic leaning symptom.
If the rear suspension moves smoothly through its travel, and the lean-in is not severe, then the likelihood is that damage will not have taken place - though action is required.
It's also the sort of job where other problems may come to light along the way if maintenance has been skimped-on (rusty brake pipes, seized anti-roll bar retaining bolts, rusty rear discs - though some of these would become apparent if the rear wheels of the car are removed).
Many hydropneumatic Citroens have this arrangement, and and it's a bit of a rite of passage for the DIY owner - there must be a sticky somewhere here, or references you can find using the search option for this forum.
If you're not a DIY-type owner, get a quote from an independent specialist for this job before proceeding any further with the purchase, or get the current owner to fix it - a keen BX owner should not be selling a BX to a first-time buyer without acknowleging that this repair is required.
Frankly, this is a weird one. It sounds like a homespun mod as a reminder to the owner or a member of their family who drove the car. Not a standard feature at all, though it does show ingenuity! As such, the current owner would have the best idea how to disable it, if they were responsible for it in the first place.
DLM
Our Trim Guru
x 13
Post by DLM »
As usual I've got a bit verbose in my reply, and learned something from the person who got in there with a reply before me. I never knew about the Aussie/NZ warnings. If you're in this part of the world, head straight for the Aussiefrogs forum for local advice on buying and specs.
kiwi
Post by kiwi »
DLM wrote:As usual I've got a bit verbose in my reply, and learned something from the person who got in there with a reply before me. I never knew about the Aussie/NZ warnings. If you're in this part of the world, head straight for the Aussiefrogs forum for local advice on buying and specs.
:lol: :lol: :lol: how very true is that :wink: The key reason for coming to the BxClub UK is it specialises in BXs where as aussie frogs I noted a lot of "advice" from members that dont have BXs. Which tends to mislead sometimes. That plus the google search engine locates this website very quickly :)
Back to the problems
Creeking noise I reckons been answered with the rear bearings at fault! Also a less obvious possibility is the Rear Brakes/discs could be a bit worn, stone or Rusty. Worth a look anyways!
The Siren/buzzer noise! Well sorry Aerodynamica I am unsure on that being a Australian Spec! But that said I am in New Zealand so that makes a hell of a differance probably? In 3 BXs I have played around with suspension down under none have this Hydraulic Light buzzer and I have no idea of its location! In fact I have never come across one in 20 years of BX ownership evn in europe.
If it can be retrofitted or connected I want one 8)
1990 BX19 TZS Auto 06/11/1989
Aerodynamica
:lol:
Ah, but Dudes, I said I wasn't sure! I thought I heard once that Aussie spec cars had a buzzer linked to the warning light.
The same Aussie rules demanded that the CX cars at least had to have a second brake accumulator fitted, significantly altering the hydraulic circuit. This meant that Aussie CXs have 3 accumulators.
No, I'm curious about this myself!
Graeme M
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
kiwi
Post by kiwi »
Australia is a flippin mystery to me as well :?
Give an example I waded into a debate over snow chains/snowtyre use in Australia. Pretty much went in there based on past UK/Europe and current NZ snow experiance. Came out if it surprised to learn a few things and licking a wound or two :lol:
The debate was how the New South Wales Road Agency was proposing compulsory carrying/fitting of snow chains to 4wd on certain roads in winter. Very enlightening and I bet to you guys who didnt know that it snows in Australia :shock:
Leapfrog
Hydraulics and Suspension
Post by Leapfrog »
........ Having said that: I believe that Australia market Citroens had a warning siren for the hydraulics in addition to the light to meet the Auz requirements - are you in Australia or UK or where?
You guessed right - I am in Sydney !
Thanks for the advice on the rear bearings - I'll knock some money off the asking price to pay for repair bills.
As for the alarm - I'll make enquiries with the local New South Wales Citroen club.
I want to buy the car and get back in to the Citroen community - I had a CX GTI Turbo II in the UK before I came down here and miss driving it. The price of used Citroens in Oz is astonishing : about three/four times the equivalent UK price !!
Post by RxBX »
Hi and Welcome 'Leapfrog',
All has been really answered as to the potential problems which you'll buying with this BX so get the seller to get it fixed or reduce the price to cover the cost if there not prepared to pay to have it done, unless you can DIY (and the car is already cheap enough) !
But to give you an overview, there's THIS recent thread which highlights the problems you'd be taking on.
Best of luck !
kiwi
Post by kiwi »
Leapfrog, is the buzzer a legal requirement then in New South Wales?
And please come back and let us know where it is located or should be? I am interested to see if the Kiwi spec had this added but not connected.
DLM
Our Trim Guru
x 13
Post by DLM »
Mr verbose back again. It's just the way I am, Kiwi... :)
Of course it no longer has Alan S to dispel potential BX bullshit - though there are some very knowledgeable Aussie BX owners on there.
I know and have met one a couple of times, even if he's at the other end of the continent from NSW, or in some far-flung corner of the world through work commitments at any given time. Of course, there's also a chance the seller could be on there already, or lurking, or selling the BX through it..
But there is the local parts/labour pricing issue, as you know...
Good call, certainly easy to check.
Leapfrog
Post by Leapfrog »
Hi, I posted a question about the alarm on the Aussiefrogs forum.
It turns out that the alarm buzzer was an Australian legal requirement in addition to the STOP sign. The alarm can be disconnected at the fusebox and some Aussie owners have done that so as to avoid the annoying sound.
B-Hive
Post by B-Hive »
Leapfrog wrote: It turns out that the alarm buzzer was an Australian legal requirement in addition to the STOP sign. The alarm can be disconnected at the fusebox and some Aussie owners have done that so as to avoid the annoying sound.
Hehehe... Australian laws can be over protective..maybe the buzzer is for the "visually challenged" driver
Find where the buzzer is and put an in line kill switch. I incidentally dont have a buzzer .(85 TRS) strange cos Australian archaic overkill sorta kicked in about '79..
Current
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
85 BX TRS mk1 auto... SOLD
90 BX TRi..parts....cubed
mike st gilles
Post by mike st gilles »
<Hehehe... Australian laws can be over protective..maybe the buzzer is for the "visually challenged" driver>
I seem to remember Alan surmising in an ancient far off thread that the reason for this 'buzzer' is on those lines.....not that the Aussie owners are at all myopic; just that with the bright sunlight (most) of the time in Oz, there was a likelihood of the warning light not being obvious.....I know that the main problem over there is not rust as here but U/V degradation of the interior of the car!!
Mike
kiwi
Post by kiwi »
[quote="mike st gilles] the main problem over there is not rust as here but U/V degradation of the interior of the car!![/quote]
The same strong Aussie sun shines just as harsh in the Land of the Long White Cloud 8)
Of course me being up on a Plateau around the 800m range does not help against the UV rays either. Rust is a problem mainly confined to the Coastal areas and the areas it rains a lot ie West Coast south island and Auckland :lol:
Which probably explais why most cars seem to be white or now the more modern ones are silver....pretty boring really.
