spigot
Red Estate
spigot
Hi, i have a set of MOMO arrow wheels with 195/50/15. it fit fine on estate but it seems that bore hole on the wheels is 73.1 mm and spigot on the car hub is 65.1 mm. as i understand that wheel bore hole must sit perfactly on hub's spigot, it is the one that take the weight of the car not wheels bolt. there is some spigot adepter on sell on internet but most of them are made from plastic. their main job is to stop a vibration. so,i wonder would it stand the load without deform sir?
- x 94
Red Estate
Surely the "plastic spigot" is for ease of wheelbolt insertion/alignment and is not in anyway structural with regard to the weight of the car? The wheel held by the bolts and against its mating surfaces on the hub is what supports the car in this regard.Red Estate wrote:Sorry about unclear on original post. Can plastic spigot in alloy wheel center bore take the weight of the car without quickly deforming or should i look for metal one sir?
Brian
- x 94
That's an area that the Steelies are better than the alloys then as the cones on the bolts micro-align the wheels as you tighten.Kitch wrote:Only issue I've ever found is that if the hub isn't a tight fit to the wheel centre, there's enough float in the bolts to allow the wheel out of balance slightly as you tighten it. Car would drive fine, until you braked! Then it'd shake itself to pieces!
Red Estate
From this www.nice-wheels.co.uk/pcdandoffset.html. they said" If you don't have the spigot taking all the weight of the car, chances are you'll break one or more studs when you drive the car hard or have to brake hard. Remember the wheel nuts are simply there to hold the wheel on, NOT support the weight of the car.
Incorrect , therefore I disagreeBrian wrote:I agree, virtualy no weight is taken on the wheel centre as that is a clearance hole. The bolts engage in a countersunk recess.
So car weight is transferred to the hub via the bolts and the interface between the wheel and hub face.
CorrectRed Estate wrote:From this www.nice-wheels.co.uk/pcdandoffset.html. they said" If you don't have the spigot taking all the weight of the car, chances are you'll break one or more studs when you drive the car hard or have to brake hard. Remember the wheel nuts are simply there to hold the wheel on, NOT support the weight of the car.
What utter crap.Red Estate wrote:From this www.nice-wheels.co.uk/pcdandoffset.html. they said" If you don't have the spigot taking all the weight of the car, chances are you'll break one or more studs when you drive the car hard or have to brake hard. Remember the wheel nuts are simply there to hold the wheel on, NOT support the weight of the car.
DavidRutherford
- BX Digit man!
Indeed. The hub of the wheel is not load bearing in any way. The wheel bolts are.docchevron1472 wrote:What utter crap.Red Estate wrote:From this www.nice-wheels.co.uk/pcdandoffset.html. they said" If you don't have the spigot taking all the weight of the car, chances are you'll break one or more studs when you drive the car hard or have to brake hard. Remember the wheel nuts are simply there to hold the wheel on, NOT support the weight of the car.
After all, how on earth can the hub of the wheel transmit the torque they are referring to from acceleration or braking? Answer is that it can't.
In actual fact, when the wheel bolts are torqued up correctly, they don't carry any of the braking or acceleration forces either, that's done entirely by the friction between the wheel and the brake disc and hub. This friction is of course only available as the wheel is being clamped to the disc and hub by the tension in the bolts.
This is correct.Brian wrote:I agree, virtualy no weight is taken on the wheel centre as that is a clearance hole. The bolts engage in a countersunk recess.
Having read a couple of pages of that web site, there's a fair amount of utter bollocks on it...
What, like this?DavidRutherford wrote:there's a fair amount of utter bollocks on it...
Just to clarify what I was saying earlier, if there is no spigot then the wheel bolts/nuts must be domed, in order to centralise the wheel…not like a Mondeo I saw recently that had the domes towards the outside "Because they look better".It is, of course, extremely important that the clearance Pitch Circle Diameterof both the vehicle body work and steering/suspension components are maintained.
