Coming back to the flock?
Well, I was offline for most of the weekend but got back home last night and immediately lobbed a bid on a BX estate - a white TGD - for £266. And won it too!
I'm off to see it this evening to see if it's anywhere near the description (some rot at base of the B pillar but lots of news goodies including head gasket, suspension 'balls' (spheres?), radiator etc).
Hope it's ok because I really fancy getting back to the BX and while I've had a 19TurGiD before, I've not yet owned an estate.
Could be an ideal tool for the BXagon Challenge...
- Keeper of the site Goat
Well, she's mine. 142k, owned since 1994 by a chap in our village, serviced at the local garage every year (expensive but good in our experience), taken to a local Citroen specialist for suspension work, fitted with a towbar, drives nicely and generally seems pretty sound bar the described corrosion. Boot floor area very tidy and it rises quickly and smoothly. Brakes are a little inconsistent, but I think it's been sitting for a short while and it might just be me not being used to hydraulics.
frugg
jonathan_dyane
Re: Coming back to the flock?
It's always good when your suspension has balls!Dollywobbler wrote:suspension 'balls'
Welcome back!
Should have mentioned earlier - my old forum name was yan_green but I changed surname, changed job, got married etc. No, I wasn't on the run...
Ten years ago, I owned a BX TGD hatch, but that was before the internet really got going. Then, about four or five years ago, I owned a Valver and I think that's about the time I checked in here.
Neither of those lasted long - six months for the TGD, eight weeks (and 4000 miles!) for the Valver. Wonder if the estate will stay for longer...
Anyway, gave the ol' girl a scrub and she's come up quite nicely.
Need some LHM now though as she's a bit low. Actually, there is a whiff of the stuff so I hope she's not leaking...
Actually, I must have some in the garage as my 2CV has the same 'life blood.' Come on rain, stop!
Matt H
- x 25
As someone on here once said: If it is made by Man it can be fixed by Man.
Sounds like you've got a common fault - either strut return pipe (doesn't usually spray everywhere though in my experience, or Octopus. Citroen still do them.
