A BIG thank-you
A BIG thank-you
Bad news…
Under BOTH washer bottles...
Corrosion all the way through to the driver's side insulation. And a hole you could put your hand through. Passenger side not too bad luckily.
View up into o/s wheel arch:
Passenger side, from top:
MOT due on Thursday. Mmmm….
Kermit to the rescue!
And what a job!
and…
The guy, I'm telling you all, is a LEGEND. Thanks Phil.
Hopefully MOT will be OK on Thursday!
ed4ferrets
Post by ed4ferrets »
Lovely job there Kermit =D>
'94 XM 2.1TD Break
'63 Renault Caravelle
Post by ken newbold »
Yep, top job! now we know where to come :idea:
Well done that man!, Fancy doing the St Tropez next?? :lol:
:roll: Phil said this'd happen if I said anything! :lol:
kermit the frog
Post by kermit the frog »
yes and i was right.
Sorry all that i have been away from here for what seems an eternity.
Probs with the steam powered computer.
I am all laptopped up now and as you can see from the pictures busy.
Still got S**Tloads to do on the green hornet pre BXAGON preperation.
Time is running out but all will be fine.
Yes Tim i can do the St Tropez but not until after the BXAGON.
Regards to all in BX land
Phil AKA Kermit the frog
kermit the frog wrote:Still got S**Tloads to do on the green hornet pre BXAGON preperation.
Not the only one mate. Got to replace the head on mine, but also rather foolishly promised my wife that I'd build the stable/garage before her birthday (17th October) seeing as I'll be heading down south on that day. Mind you I didn't specify which year!
Still, got the base done, and laid the first course of bricks so at least I've made a start...
kermit the frog wrote:yes and i was right.
Thanks for the offer Phil! 8)
