Dashbulb Location
Dashbulb Location
Ive changed alot of dashbulbs on BX's over the years, Ive either had a mental block or I just cant work out where the one is that illuminates the lefthandside (as you look at it) of the speedo fuelgauge and oil pressure gauge is located.
I spent an hour changing the ones on the right hand side of the speedo and heater controls, display module clock etc but the furthert left of the dash is still dark, I lost my temper swore at it and went in for a cuppa!
Thanks
Brian
Post by Brian »
Well, if it is the Veglia dash, then there is no ilumination to the left hand side of the petrol and oil gauges, but there are 2 located on the letft hand side of the speedo head as you look at it.
To get at them, you have to remove the white plastic cover over the small PC board, 1 screw, then you will see them.
I will try and get a photo up later.
Good luck and have another cuppa.
Thanks Brian, much appreciated!
Brian
Post by Brian »
Picture below.
The two bulbs in question have been removed to indicate the ones that require replacement.
All sorted now thanks again Brian, every single dash bulbs works (for now) even the auto shifter! lol
