BX rear brake caliper parts
Aerodynamica
Hi all, my mate's BX TZD Estate needs a new part for one brake caliper - it's the little 4(?)mm by 90mm bolt that goes through the 2 pads, both caliper halves and secures the little tin cover for the front of the pads.
Anyone know if this is a standard machine screw? seems pretty thin for its length and is only threaded on 10mm of the end.
Any ideas?
Any ideas?
Graeme M
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
'c'est hydropneumatique'
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
It certainly is a standard thread (M4 IIRC) - I can't see that it would matter whether it's threaded all the way or not. You can get the rear brake fitting kits from some motor factors for about a fiver; I got one about a month ago from CES (which was made by AC Delco) which includes the dust shields as well, which tend to rust away.
If you're really stuck I have a usable spare screw.
Citroen still sell the bolts, although they don't come with the nut
That must be another part you would need to order if the old one is damaged when trying to unseize the bugger....
As Mat said, probably best to get the kit which will include everything that you need.
Aerodynamica
hmmmm, sounds wrong to me, unless of course it's another part that is no longer available
If you get stuck pm me, i may be able to find one in my parts bin.
Re: BX rear brake caliper parts
Yes Graeme !Aerodynamica wrote:Hi all, my mate's BX TZD Estate needs a new part for one brake caliper - it's the little 4(?)mm by 90mm bolt that goes through the 2 pads, both caliper halves and secures the little tin cover for the front of the pads.
Any ideas?
I nearly scrapped one today which had 4 worn pads dangling from it, but I thought ?
I'll remove that the long set-screw 'Just in-case', so PM me where to send it and I'll put in the post for your Mate
- x 117
Graeme wrote
"this bolt only comes with a new caliper"
here are the part No's. and trade price's inc VAT from service citroen
bolt 5438691 5.59 pounds
washer 790358027 0.03p
washer 96108079 0.75p
nut 693322 0.16p
spring 95608524 0.92p this is the pad anti rattle spring
guard 5438689 1.46 pounds
TOTAL 8.91 pounds
nut 693322 0.16p
TOTAL 8.91 pounds
Linegeist
snot hard Bob realy you just need to see if service citroen will accept your registration request, as i hear some people have been locked out
Aerodynamica
kiwi
- x 4
Recent experiance of changing rear brake pads
It took over two weeks to be done
First set sent delayed and they ended up by front pads not rears! Second set missing in post! Third set arrived but wrong type basically they were for a CX according to the box and turns out a mismatch on the euro/kiwi cross referancing manual. Finally Monday the correct set arrived and it took me all of 30 minutes to install both sides
I did not for future referance that the box stated xantia! Does this mean that the Xantia has the same rear pads for future referance?
1990 BX19 TZS Auto 06/11/1989
Must admit i thought xantia rear calipers were slightly different & although the pads look the same, they are slightly larger?
kiwi
- x 4
Well something went wrong in the cateloging the first set of rear pads looked the same until tryed to fit and found them 5mm to large.MULLEY wrote:Must admit i thought xantia rear calipers were slightly different & although the pads look the same, they are slightly larger?
Would be good if someone with a Xantia and a BX could confirm the sizes of these pads are the same. Settle a debate before it turns into another Tyre saga.
